home made carbon fiber dust caps DIY - Car Audio Classifieds!
Old 07-28-2014, 07:34 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Default home made carbon fiber dust caps DIY
thought id toss together a little DIY for people that may want to try it out for the fun of it. making your own carbon fiber caps. while it may not be the most fun, its cool as hell to see it finished and you can pick your own material.
to start-
safety-
  • well ventilated area, high on fumes -> brain damage
  • 75 degrees + -> cures faster
  • gloves -> its sticky stuff
material list-
  • gloves
  • paint brush, preferably 2"
  • carbon fiber fabric
  • decent painters tape
  • resin and hardener (Wal-Mart)
  • mold of some sort
  • mixing tray/bowl *not foam
  • sharp scissors
  • mixing stick/mix utensil
  • the pink bondo spreader is to straighten the weaves in the carbon fiber, not completely needed
first, gather all your supplies
decent pair of gloves to keep the resin off your hands
a paint brush that's not foam, 2" works well
carbon fiber of your choice, any kind
decent painters tape, not clear tape or duct tape
resin and the provided hardener, it was ~$20 at Wal-Mart in the audio isle ish area
mold, an old dust cap that's smooth will work, as long as there's no paint on it.
mixing utensil, I used a plastic knife
mixing bowl, not made of foam. it will eat it/melt it
sharpest scissors you have lol
go some where there's good air movement and its 75 degrees plus (above or below is fine, it'll take longer to cure if below 75)
lay out all your materials you'll need. look at it.............. stop
unroll some fabric, enough to do your cap plus some
place the part on and lay tape about an inch from all the edges so theres a little carbon fiber extra
then cutout the fabric, cutting in the center of the tape
at this point use your finger to straighten any messed up strands in the fabric so there all as straight and smooth as possible, then set it to the side carefully
clean the molds surface, there should be no paint or It will pull the paint after the resin eats it alive
then pour some resin in the mixing container. a little extra is better then not enough
I used about a half cup of resin... then added 6 drops of hardener. too much will cook/crack it. too little and itll just take longer to cure
stir it a lot, nice and slow figure 8 is fine. don't be shy to take a minute to stir
then apply a nice thin coat... be thorough, make sure you coat everything
next part wasn't pictured since I was born with 2 hands... hold the fabric over the mold and start sticking the fabric in the center and work your way out. do not start on the outside. touch in the center, drag your finger gently outward
this ^^ would be the dry look, if you plan to try that, thin coat on the form or it will bleed thru.
now coat the cloth very gently with a nice thin coat... go with the grain ( the same direction as the lines) not too much or itll pool, you can always coat a little more later if needed . coat beyond the edge of the mold, itll save you big time when you clean cut it later on
drag the brush gently across the coats after each application to get any extra off
more to come when mine cures
if you want thicker caps, repeat the steps again
The Following 3 Users Say Thank You to Jeffhulbert50 For This Useful Post:
Blaza33 (07-28-2014), dbsupra (07-28-2014), youngkcity (07-28-2014)
Old 07-28-2014, 07:40 PM
doug118's Avatar
0/11 sssss4674
Cool idea
Old 07-29-2014, 12:42 AM
Authorized Vendor
0/11 ssss14115
and the finishing process ( you could hit it with a ton of clear if wanted)
first, leave it in the mold, I acts as a nice pattern to follow as you cut. I like to start by trimming the bulk away then the smaller
then trim around again getting nice and close, take your time
and done
[IMG][/IMG]
now mold release
diy carbon fiber caps - YouTube
this is the back impregnated with resin...mmmmmm
Old 07-29-2014, 12:51 AM
0/11 sssssss61
looks great, how do these compare to the DD caps
Old 07-29-2014, 05:46 AM
Authorized Vendor
0/11 ssss14115
DD will be better which is t be expected of a long time established company..these come out good looking and strong
Old 07-29-2014, 07:42 AM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Thank you sir!!!
Old 07-29-2014, 07:46 AM
0/11 sssss4519
Outstanding. I've been needing some 3'' caps and nobody makes them.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 11-11-2014, 01:58 AM
0/11 ssssss512
how does the weight to strength ratio compare doing it this way vs a poly cap
how many layers are needed to make it stronger
Old 11-11-2014, 04:38 AM
Authorized Vendor
0/11 ssss14115
Strength of one layer is slightly more then poly with equal to slightly more weight due to resin. 2 layers criss cross would be pretty strong once glued to a cone
Hard Carbon Fiber Dust Caps us3 Speaker Accessories & Parts 7 09-03-2012 07:27 PM
(2) Carbon Fiber dust caps MarioB Speaker Accessories & Parts 8 08-31-2012 12:25 PM
2 DC carbon fiber dust caps burzendowski Speaker Accessories & Parts 5 04-09-2012 07:39 PM
Carbon fiber dust caps? basshead08 General Car Audio Discussion & Questions 12 12-06-2011 05:41 AM
[WTB] 4- Carbon fiber dust caps docpep Wanting to Buy (WTB) 1 09-11-2010 06:22 PM
