Subwoofers that sound "good" vs those that sound "bad" - Car Audio Classifieds!
Old 09-12-2009, 11:43 AM
Wheres The Butta's Avatar
0/11 sssss6101
Feedback Score: 21 reviews
Default Subwoofers that sound "good" vs those that sound "bad"
Something that I personally (and many others as well) are probably tired of telling every new member... I hear the same question over and over again - "Which subwoofer will sound better?" or the other variation, "Which subwoofer will get louder?" I just wanted to post some quick facts about subwoofers that the newcomer will benefit from knowing.
The biggest factor in whether a subwoofer sounds "good" or "bad" (or loud) is not the woofer itself. It's the install: that means the box and box placement, sound deadening, the amount of power you're running, the subsonic filter, and the crossover point. Probably the single most important consideration in getting loud is the enclosure. A crappy enclosure will gimp your outpt no matter what you're running, but a good enclosure can allow even low budget woofers to have decent output. Make sure you run the right kind of enclosure for your woofer and for your application.
The subwoofer itself really has a comparitively small role in sounding "good". Different subwoofers are suited to different things, but just about any subwoofer of reasonable quality can sound "good" if it's installed properly.
When people say something sounds "boomy" they're generally talking about the response curve having nasty peaks - that mostly has to do with the box, the EQ, and the vehicle; it also has to do with the fact that subwoofers are usually running on 10x more power than the front stage, so the volume of any note they play is exaggerated. This generally doesn't have much to do with the subwoofer itself.
When people say a subwoofer sounds "tight" and they're talking more about characteristics of the enclosure. A small sealed box will have more of a "tight" sound to it due to the air pressure within the enclosure. As the subwoofer cone moves in and out, the internal air pressure will attempt to pull the cone back to the resting position. As the driver begins to approach full excursion, the air pressure is very great, and thus full extension is not as easy to reach as a vented enclosure; however as the woofer oscilates, the transition from one note to the next is facilitated by the air pressure. This ease of transition but difficulty reaching full extension is what causes the "tight" response of a sealed enclosure.
Vented enclosures are more efficient and allow greater output by effectively doubling the output of the speaker. What they do is utilize the waves created by the REAR of the speaker cone to reinforce those created by the front of the cone. In a sealed enclosure, the waves created by the rear of the speaker cone aren't heard because they are contained within the enclosure. Due to the vented enclosure having less internal air pressure as compared to the sealed enclosure, it isn't as controlled or "tight" - but it does have much more output.
As far as the crossover point - Midbass is typically "punchy" so if you cross your subwoofer too high, you'll hear "punchy" bass produced from it. You want to cross your subwoofer over 80hz or lower - never higher unless you're more experienced and building an advanced SQ system.
Subsonic filter - you really can't hear anything below 20hz, but those frequencies still require power to play. By eliminating the frequencies below 20hz you save your amplifier and subwoofer some unnecessary effort. (these frequencies are used for sounds like explosions and car crashes, so if you're watching a movie you might want to have them on)
Sound Deadening - this is important for both SPL and SQ. If your whole car rattles when the bass hits, it's going to sound like absolute garbage. Are you trying to listen to bass or the sound of your car falling apart? Sound deadening also has the wondrous effect of strengthening the panels of your car, so that they don't flex as much and thus can build more internal pressure (SPL). Sound deadning is good stuff.
Power: It's always better to have extra power on tap. Remember, if you have extra power on tap, you don't have to use it. If you have too little power to really get your woofer moving, the tendency is to turn the gain up on the amplifier... when you do that, you're most likely exceeding the amount of power the amplifier was designed to produce, and you are most likely giving your speaker a clipped signal - this is one of the most common causes of a blown subwoofer. I'll say this flat out - clipping is the mortal enemy of ALL subwoofers, and can be avoided 100%. Having more power available is ALWAYS better than less.
Cliffs:
"Boomy" generally has nothing to do with the woofer itself.
Boxes
Sealed = tight and punchy because of air pressure controlling the cone
Vented (ported) = twice as loud because it uses the waves created by both front AND back of the cone rather than just one side, but lose some control of the cone due to less air pressure
Since this is just for beginners and because it would take a looong time to fully explain, I'm not going to get into bandpass.
Crossover points - Low-pass at 80hz or less and subsonic at 20hz.
Sound Deadening - Use it to increase panel rigidity and eliminate vibration.
Power - always better to have extra headroom, do NOT crank the gains to compensate for a weak amplifier or else you will clip the signal and may damage your subwoofer
____________________________________
IASCA Pro AM and MECA Modex -->
Old 09-12-2009, 11:46 AM
justin smith's Avatar
0/11 ssssss653
sticky?
Old 09-12-2009, 11:53 AM
0/11 sssss6101
Originally Posted by justin smith View Post
sticky?
I hope so
[SOLD] 15" Sound Stream XXX BNIB SPY 15" Subwoofers 26 01-09-2010 10:11 PM
[SOLD] 2 12" dc sound lvl3 dual 4 teamsolo 12" Subwoofers 10 09-09-2009 12:42 AM
wtb 2 12" DC sound lab lev 4xl or lev 5 loudaccent Wanting to Buy (WTB) 9 06-23-2009 09:41 AM
[No longer for sale] 15" Sound Stream XXX SPY 15" Subwoofers 0 06-12-2009 03:42 PM
[SOLD]DC Sound Labs 10" Level 4 A.I. James 10" Subwoofers 7 12-01-2008 06:21 PM
