Basics, subwoofer motors and flux - Car Audio Classifieds!
Old 01-04-2015, 05:42 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Default Basics, subwoofer motors and flux
i know some people aren't familiar with subwoofer motors and how exactly they work so the following is just some notes on whats happening in a motor as well as the coils interaction while in the motors gap. keep in mind this is generalized. different motor types such as MMAG/XBL^2/split gap/etc may not work in the exact same way. what is the same however is the magnetic flux lines and poles of the magnet
the model is a cut out of a motor. 1/4 piece. for example if its confusing, it looks like this in a real motor
overall layout of the parts
below is a magnet. notice the skinny black hair like lines make loops/curcuits from one pole to the other. N is north, S is south (if wondering)
lets use the magnet in a motor.
closer look at the motors lines
add a coil to a model
the last two models show how a coil can be affected when a driver is under high excursion. the coil its self needs flux to push away from/pull to. if the coil begins to leave the gap, it looses lines to grab which drops the BL power
please keep in mind this is all GENERAL
The Following 7 Users Say Thank You to Jeffhulbert50 For This Useful Post:
97_eldo (01-04-2015), andy75 (01-04-2015), cerwinvega_fan (01-04-2015), hurrication (01-04-2015), Nate Futuristic (01-04-2015), TaylorFade (01-04-2015), Todd Dupler (01-04-2015)
Old 01-04-2015, 06:10 PM
0/11 ssssss266
thanx for taking the time to put this together.
always enjoy the educational tutorials
mentally unstable but otherwise just messed up.....wooohoooo
Good luck on your journey
take care and have fun
Old 01-04-2015, 06:26 PM
Souldrop's Avatar
0/11 sssss1270
Awesome post. Thanks Jeff.
2016 Scion iM
- Bone stock for now
Old 01-04-2015, 06:28 PM
0/11 ssssss543
Not 100% sure but having to small a back plate and large pole vents also cause a pinch point in the flow of flux weakening the gap.
Old 01-04-2015, 06:30 PM
Authorized Vendor
0/11 ssss14115
potentially yes. if theres more magnetic material then steel can effectively accommodate then it can cause a pinch or bottle neck that will kill the efficiency of the motor. too thin of a top plate and it fully saturates too easily causing the back plate to suffer also since they need to work as a team.
Old 01-04-2015, 06:38 PM
Authorized Vendor
0/11 ssss14115
pole too thin/small
top plate too thin
back plate too thin
Old 01-04-2015, 07:09 PM
0/11 ssssss543
And for those that don't know the goal is to have the purple in the gap only without using excessive amounts of material.
subwoofer motors chevy454 General Car Audio Discussion & Questions 2 03-28-2014 11:24 AM
scosche efx flux OFC 1/0 47ft spool select127 Wiring, Electrical & Other Installation Equipment 0 10-05-2013 10:59 PM
f/s New 4ga power wire FLUX select127 Wiring, Electrical & Other Installation Equipment 0 08-04-2012 09:40 PM
harrison sound labs 100amp flux capacitor voltage regulator ampjunkielikeme eBay 1 08-08-2011 12:03 PM
fs: Harrison Labs Flux Cap 100a ssackett Wiring, Electrical & Other Installation Equipment 20 02-16-2009 08:40 PM
