Quality Line Output Converters??? - Car Audio Classifieds!
Old 01-24-2016, 09:26 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
Default Quality Line Output Converters???
I just bought a new vehicle.... 2015 Chevy Malibu, and there isn't a dash kit available yet, I'm missing my bass..... I have EVERYTHING I would need to get a system going... i have subs amps door speakers,,, only problem is getting signal to the aftermarket amps...
My question, is there any decent line output converters? In my car there isn't a set of rear speakers... in the trunk that is.. so I have to run and pull line from the rear door speakers.
i'm trying to keep this setup as simple as possible, so that It stays clean, Just want something simple and have some bass back...
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 01-24-2016, 10:53 PM
0/11 sssss2011
Feedback Score: 61 reviews
if you don't have digital climate controls
Metra Online
if you do, i'd look at Audiocontrol or PAC
Old 01-24-2016, 11:07 PM
I'm F*CKIN Sexy!
0/11 sssss2132
Metra Online
I don't however my vehicle has the mylink unit, and this kit doesn't work with the mylink unit.
Sealed 152.9
Outlaw 156.6
Old 01-24-2016, 11:09 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
PDLC21 is the way to go. Or a cache cloc+D if you can find one (it's got a metal case but the same internals, one has the led's on top, the other the side)
The LC2i is much bigger and doesn't have RCA to RCA but if you only plan to use if for LOC, it's great. It even has a port for the remote but it's like $20 extra. Also, it takes one left and one right and puts out 2 RCA's, which the pdlc21 and cloc+d do not do, so it has that going for it. But it's a lot more expensive.
As far as the AccuBass feature
The AudioControl LC2i features AccuBass processing for correction of bass roll-off. AccuBass processing automatically corrects for the bass roll-off that is common with many factory installed audio systems. AccuBass Bass Compensation works at any volume level.
I did not notice any difference with a stock 2010 hhr unit with 3.5mm with any of the 3 LOC's vs a pioneer 4v unit with ipod. However, I assume SOME stock units compensate bass output at higher volumes to prevent distorting, as it states.
I have all 3 if you have some PA 6.5" 4 ohm mids or a 4v ipod touch unit to trade.
team graham
I'm F*CKIN Sexy!
0/11 sssss2132
i'm looking at the pac 7lt 4ch pro loc, but i also stumbled across the ag-gm44 from pac... its a gm amp integration unit.... but we will see.... it shows for 2012 and up, without premium stereo, but i sent an email because its not a brand specific premium like bose or pioneer setup...
Sealed 152.9
Outlaw 156.6
Old 01-24-2016, 11:17 PM
I'm F*CKIN Sexy!
0/11 sssss2132
As far as the AccuBass feature I did not notice any difference with a stock 2010 hhr unit with 3.5mm with any of the 3 LOC's vs a pioneer 4v unit with ipod. However, I assume SOME stock units compensate bass output at higher volumes to prevent distorting, as it states.
I do actually lol, I have a few pioneer pro 6.5 midbass drivers they are the ts-m650pro
Sealed 152.9
Outlaw 156.6
graham's Avatar
Tinder Douchebag
0/11 sssss7095
Got a gm13sr too
team graham
Old 01-25-2016, 12:06 AM
jeffdachef's Avatar
0/11 ssssss440
Those audiocontrol analog line out convertors are outdated dinosaurs man. Get a digital signal processor.
Like this
Soundstream Harmony Car Audio 31 Band Digital Sound Processor Cirrus Logic | eBay
Much better sound quality. Accepts your speaker inputs and gives out 8 rca channels of output. Bandpass capable crossovers 20hz to 20khz with up to 48 db slope. Means you can do midbass, midrange, tweeter and subwoofer all actively controlled and crossed over and time aligned and 31 bands of EQ.
Audiocontrol has zilch options in comparson.
Old 01-25-2016, 12:08 AM
jeffdachef's Avatar
0/11 ssssss440
It also has a bypass factory EQ option in the software too.
Old 01-25-2016, 12:19 AM
I'm F*CKIN Sexy!
0/11 sssss2132
so basically with that unit, I could load the software into my laptop, plug the unit in to it in the car, set everything with the laptop, set each channel how I see fit, and run it to the amps, do the speaker lvl input, and it be ready to rock? thats pretty freakin awesome!!!
Sealed 152.9
Outlaw 156.6
Audio control Lc2i line output convertor+line driver stopdrpnro Wiring, Electrical & Other Installation Equipment 0 08-01-2015 02:24 PM
new peripheral SVENR 2ch line output converters Nudels Wiring, Electrical & Other Installation Equipment 0 05-02-2012 12:19 AM
Line Output Converters RidnClean General Car Audio Discussion & Questions 3 10-03-2009 01:00 AM
Line-Out Converters? nathanf2009 General Car Audio Discussion & Questions 16 07-11-2009 11:18 PM
Fuse holder, Output converters, Boxes FS worstenemy453 Wiring, Electrical & Other Installation Equipment 2 10-22-2008 03:58 PM
