[BASIC] Designing a Sealed Enclosure - Car Audio Classifieds!
Old 11-12-2008, 03:34 PM
danteBirosel's Avatar
0/11 ssssss476
Default [BASIC] Designing a Sealed Enclosure
Props to seth50 @ caraudio.com
Calculating cubic foot
This only works for standard boxes, not wedge boxes or circular ones.
Ok, you got a sub and now you want to make a box for it. Then you decide if you want the box ported or sealed. Lets do both.
Sealed Box
Lets say the sub needs 2.0cuft sealed.
What you would do now is measure the maximum amount of space in your trunk or where ever your putting the box. Measure Length, Width, and Height because you will need those 3 measurments for the box.
Lets say your maximum measurements are......45"x24"x20"
You now take those measurements and get the cuft for that amount of space.
You do that by taking each measurement and subtracting 1.5 from each one and then multiply them all together and then divide by 1728.
So it should look like this:
43.5x22.5x18.5=18106.875 then divide 18106.875/1728 = 10.49cuft
Ok naturally 10.49cuft is too much. So now you mess with your measurments until you get 2.0cuft.
Ok, 20"x16"x14.4" = 2.0cuft, but since I dont like working with uneven numbers, Im just going to go ahead and make 14.4 = 14.5. Which now makes the box 2.02cuft.
Now you have your measurments that you need to cut. But remember when you cut to compensate for the thickness of the MDF which .75
Like for instance on my box I built I forgot to compensate for it and I ended up have to trim the front and back down.
All you do is subtract 1.5" from your measurment and then the piece should fit down in between the sides.
Now, you have that....now take your subs displacment and add it to your cuft of your box. So its, 2.02cuft+0.08cuft = 2.1cuft. Now thats how big your box must be in order for your box to have 2.02cuft after the sub is put in. So once again you adjust your measurments accordingly.
So now your measurments become, 20"x16"x15" = 2.1cuft
Now your sub can go in the box and have 2.02cuft.
Now you have your measurments that you need to cut.(20"x16"x15") But remember when you cut to compensate for the thickness of the MDF which .75
0/11 ssssss476
For a wedge box, you will need to separate the different shapes of the box.
Take a truck box; you have two shapes that make it up: a a rectangular prism (or cube), and a triangular prism. Find the area of the rectangular portion like described above. Then, take the 'wedge' part (the triangular section), and find the average of the two depths. IE. (Depth1 + Depth2) / 2. Multiple this by the width and height of that section.
Now, add the two together, and thats your volume for a wedge enclosure.
[BASIC] What is Fiberfill and How Does it Affect an Enclosure? danteBirosel Sound Deadening & Fabrication 11 01-25-2015 04:06 AM
[BASIC] Sealed vs Ported vs Bandpass (4th order) danteBirosel Tutorials & Quick References 0 11-12-2008 02:47 PM
[BASIC] What's the Best Wood to use when Constructing an Enclosure? danteBirosel Tutorials & Quick References 0 11-12-2008 02:46 PM
[BASIC] The Basic Installer Tool List danteBirosel Tutorials & Quick References 0 11-12-2008 02:41 PM
1.0 ft^3 sealed for a TC OEM SPY Off Topic Chat 4 09-07-2008 07:46 PM
