[MODERATE] How To: Carpet an Enclosure with Router Bits - Car Audio Classifieds!
Old 11-12-2008, 03:37 PM
danteBirosel's Avatar
0/11 ssssss476
Default [MODERATE] How To: Carpet an Enclosure with Router Bits
Props to bjfish11 @ fiberglassforums.com
I was asked to post this here. Enjoy.
Alright, I finally have time to sit down and post this up. I will try my best not to miss anything, if i do, just post the question and i can go back and edit or just answer it for you. Any way, here it goes.
This technique that i use involves routering the edges or the sides with a rabbiting bit, and routering a groove in the top, bottom, front and back pieces with a straight cutting bit. This will allow you to have a very small groove to tuck your carpet into when the time comes. Not only that, but i believe it makes the actual assembly easier. Here is a pic of a rabbiting bit that i use.
You will need to set this router to a depth of a hair over 3/8" if using 3/4" MDF. Your straight cutting bit should be set at a depth of about a 1/4". By doing this, the rabbited edge will sit in the groove and still leave about a 1/8" seam around the whole side. So after you get your design, you will need to add 1/4" to EVERY edge that will get the rabbited treatment. For example: If you box is outside dimensions of 12" Wide x 12" Tall x 12" Deep, then your panels will consist of 12 x 12 for the top and bottom and 10.5 x 12 for the front and back, and typically your sides would be 10.5 x 10.5 if you were to inset them. So you need to add 1/2 inch to the length and width bringing your sides to 11 x 11. I hope this all makes sense, if it doesnt now, it should as the tutorial goes on.
So after all your pieces are cut, you need to router them accordingly. The sides go the the rabbiting router table and the back, bottom, front, and top go the the straight cutting router table. You can set the straight cutting router table to cut in however far in you want your sides to sit from the edge. I go in about an inch, making a 1/4 inset lip when it is all said and done. Here is what the rabbiting pieces should look like when the are finished:
Here is what the straight cut routered pieces should resemble:
When they are assembled together, here is how they will look:
Notice there is a small groove all the way around the sides. This is where the carpet will be tucked to achieve a seamless finish on the sides.
You will need to repeat this for the other side and all the panels. Then glue it up and screw it together. Be careful not to screw too close to the ends in order to prevent splits in your wood. Now the build up will be complete. I will continue on to the carpeting section in my next post. Keep reading.
Now for the carpeting.
We will do the sides first. Measure your sides, and then cut your piece of carpet a little bigger both ways. I just simply add about an inch. Then spray your actual side, and also the side of the carpet that will go down on the box. Then put on your carpet and press it firmly down to get all the wrinkles out. I start and the center and work my way out. Make sure there is overhang on all the sides. Here is what it will look like.
Now take you a razor, and run it in the groove to cut off the excess.
Do the same thing with the other side, and then we are ready for the rest of the box.
There will be 1 seam total on the whole box, so now is when you need to decide where to put it. Obviously, the bottom is the best choice, so thats where we will put it on this box. You need to cut a piece of carpet that will be big enough to wrapped around the entire box and wide enough to over hang each side at LEAST 2 inches. Cut that piece, then, starting on the bottom, glue it down using the same method as before (spraying both the wood and the back of the carpet). However, we want to start this piece in the MIDDLE of the bottom panel. This is where our seam will be. Dont worry too much on getting this piece laid perfectly straight, it will be trimmed in the end. Just make sure you keep the sides even, or you may run into problems when it comes time to tuck the edges.
Now, continue to glue the carpet down on the remaining panels one at a time, working you way back around eventually to the bottom.
Old 11-12-2008, 03:38 PM
0/11 ssssss476
Now, to finish with the bottom, glue the carpet UP TO your original starting point. Then lay the remaining carpet over the original starting point, and lay a level across your carpet, and run a razor through what will be 2 layers of carpet.
This is what it will look like after you have cut through both layers of carpet. Peel back the pieces as far as they are not glued down and proceed to glue them down. Then you will have a perfect seam.
[img]
http://img233.imageshack.us/img233/1971/boxtutorial0242lt.jpg[/img]
Grab the hung over parts at the corners and pull them down tightly to form a good tight 45* angle. Then take your scissors and cut them down flush with the edges of the box.
Sorry for the crappy pics.
0/11 ssssss476
Do this for all 4 corners and then you need to trim up the pieces so the are just long enough to be tucked down into the seam.
Do that too all the sides, then we are ready to begin actually tucking.
Spray glue on the edge of the wood for one side at a time, then take a flat head screwdriver and begin pushing the carpet down into the groove.
Contine to do this to the whole side and repeat these steps on the other side.
Then go back and cut out the carpet for the mounting holes, the ports, and the terminal holes.
And you are finished.
Hope this was helpful to everyone that needed some more info on carpeting. If i missed anything, or failed to explain clearly, post it up and i will answer your question. Sorry for all the bad pics, didnt realize they were so bad when i was building the box.
By the way, this box was HUGE. We had to do some "special" packing to make this thing so it could be carried.
Covering An Enclosure. Help worstenemy453 Enclosure Discussion & Design Construction Help 13 12-02-2008 05:49 PM
[MODERATE] How To: Learn How To Build Your Own Enclosure danteBirosel Tutorials & Quick References 2 11-12-2008 03:24 PM
[MODERATE] How To: Design a Ported Enclosure danteBirosel Tutorials & Quick References 0 11-12-2008 03:23 PM
How to Carpet a box SPY Tutorials & Quick References 2 10-01-2008 11:36 AM
