How to set your gain voltage 101 - Car Audio Classifieds!
Old 03-24-2010, 10:47 PM
Slammintriple6's Avatar
0/11 ssssss594
Arrow How to set your gain voltage 101
50hz is the best for music.70hz is more for spl/farts imo
(Sticky me please)
Old 07-27-2012, 02:52 AM
0/11 ssssss320
Default setting gain on amp problem
i tried setting my wifes gain on her amp its only a 400 watt kicker amp and l3 i couldnt get 28.8 just with the gain the only way i got that was by turning the gain all the way up and the bass boost all the way up i did everything right not sure why i had to max out both the gain and bass boost i had my dmm in the right ac volts has anyone experienced this before could it be because the amp is only 400 watts rms
Old 07-27-2012, 03:20 AM
The Slouich
0/11 sssssss94
Could be your rca voltage.
Old 07-27-2012, 04:40 AM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
Most likely RCA voltage coming from the head unit is low. Bass boost is a no no btw.
Old 07-27-2012, 04:53 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
No offense but I don't really think this is sticky worthy...
Here is a good one.
gain setting tutorial 2010 - Realm of Excursion
Only thing I do differently than with the above is leave the subs hooked up. The difference is small but that's just my preference.
Current Build:
#60sHereIcome
Old 07-27-2012, 04:57 AM
SINTORMAN's Avatar
0/11 sssss4907
And there are a couple things wrong with the method in the pic you posted.
1. They don't list a recording decibel level for the tone. I recommend -5 or -3 depending on the user's experience level.
2. Do not set your gains with bass eq's off then turn them back on after. This will most likely lead to clipping and or over powering which is a bad thing.
3. Depending on the deck the sub level should be maxed out. Can't say for all but decks like pioneers it is an attenuation. So full output is at +6. You want it at that for good pre out voltage for setting your gain.
Current Build:
#60sHereIcome
Old 07-30-2012, 05:36 PM
whos that's Avatar
0/11 sssss1635
I have a cheap pioneer headunit, would SLA be the sub output? I know it gets louder when I turn that up lol, maybe that would explain my I couldn't really get a reading from my amp, I tried to measure voltage and the SLA was at like 1 out of 4
Old 07-30-2012, 06:34 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
no you should have the sla at 0
Old 07-30-2012, 06:35 PM
SINTORMAN's Avatar
0/11 sssss4907
SLA is for matching input signals across sources. CD,AUX,USB
Current Build:
#60sHereIcome
Old 07-30-2012, 09:29 PM
whos that's Avatar
0/11 sssss1635
Ah. Thank you.
Amp Gain Setting the Right Way whitedragon551 General Car Audio Discussion & Questions 19 03-30-2010 02:20 PM
setting Gain help tylork92 General Car Audio Discussion & Questions 4 11-25-2009 11:16 PM
How high is your gain set? hornedfrog1985 General Car Audio Discussion & Questions 7 09-05-2009 04:42 AM
WTB remote gain knob z1a peas247 Wanting to Buy (WTB) 1 03-31-2009 12:02 AM
Bass/ Gain Knob for Ab 400.1? mazda6i07 General Car Audio Discussion & Questions 3 03-23-2009 02:04 PM
