Fiberglass finish milkshake mix - Car Audio Classifieds!
Old 07-18-2010, 06:41 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
Default Fiberglass finish milkshake mix
what do you guys use for your milkshake mixes.
do you use fiberglass resin, and fiberglass resin hardner with some body putty filler in it.
or, do you use the creme hardener with body filler, then just add resin?
what I'm asking is what is the mix for milkshake for finishing off body filler/resin etc? for say glassing projects
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 07-18-2010, 06:52 PM
you use
resin and resin hardener
and
body filler cream hardener
Old 07-18-2010, 06:57 PM
I'm F*CKIN Sexy!
0/11 sssss2132
really? because I've used the body filler in some applications, just don't remember what mix I used... i believe it was using the resin hardener or using the bondo hardener.
I think i just added filler, in with resin and resin hardener.
Sealed 152.9
Outlaw 156.6
Old 07-18-2010, 07:03 PM
no you mix both up separately then mix together. that way both parts are mixed right
Old 07-18-2010, 07:07 PM
I'm F*CKIN Sexy!
0/11 sssss2132
ok
Sealed 152.9
Outlaw 156.6
Old 05-08-2011, 09:57 PM
LunchboxCritter's Avatar
Disco Biscuit
0/11 sssssss43
The cream hardener in body filler is actually MEKP just like used in poly resin. I have read that you can just use MEKP in the mix (resin/bodyfiller).
I personally mixed the body filler with the supplied hardener, and the resin with the mekp. I then mixed the two together. Here is what I got (duraglas, and B440 US composites resin).
-LunchboxCritter-
Old 06-27-2011, 01:47 PM
0/11 sssssss72
I mixed mine all together also the first time, didnt turn out great !! But when i mixed them seperatley and then together it worked out great !!
Old 03-07-2012, 10:15 PM
0/11 sssssss14
mix separate then add them together for the best mixture!!
Old 06-12-2012, 01:20 AM
wewejonson's Avatar
d d audio 4 life
0/11 sssssss91
what is the uses for this mix? is it stronger the just fiberglass resin, for reinforcing corners in a box build or do you pore it over fiberglass to fill the tiny imperfection for painting and to cut down on sanding time
Old 06-13-2012, 02:43 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
what is the point of this... i need to school up more on my fiberglassing
you probably wont like me
does someone here do fiberglass? iamlayinframe Off Topic Chat 2 01-11-2010 02:22 PM
[SOLD] NIB JL Audio 500/5 in rare all black finish from factory. SPANKYSPL Multi-channel Amplifiers 24 01-04-2010 10:16 AM
pics of piano finish on mdf Allstar71 Build Logs 37 12-24-2009 08:14 PM
Help finish up box design gbo559 General Car Audio Discussion & Questions 8 08-23-2009 02:42 AM
Finish Box Paint & Girls Acura Build NoPh33rRaCiNg Build Logs 29 01-04-2009 06:04 PM
