How to apply polish or paint sealent. - Car Audio Classifieds!
Old 01-04-2009, 11:52 AM
DLP customs
Guest
0/0 sssssssss
Default How to apply polish or paint sealent.
Car Wax & Paint Sealant Application Techniques
Credit to autogeek.net
How to Apply Car Wax & Paint Sealants
Once you’ve chosen a car wax or paint sealant, you’ve got a couple of application options. You can apply it by hand or with a polisher. Even paste car waxes can be applied with a polisher.
Hand Application
  1. Apply car wax or paint sealant in the shade. If the product dries too quickly or sits on the vehicle too long, it may be difficult to buff off.
  2. Always apply car wax or paint sealant to a dry vehicle. Droplets of water on the paint will cause the product to streak and it will be unnecessarily tough to buff off.
  3. Thin, thin, thin! Apply the thinnest coat you can. If you want more shine and depth, you’re not going to accomplish it in one thick coat. It just makes the wax or sealant difficult to remove and streaky. Buff one coat off before applying a second extremely thin coat. Check the label to see how long one coat has to cure before applying another (usually 12-18 hours).
  4. Poly foam wax applicators are the best for achieving a thin, even coat. They’re absorbent, durable, washable, and reusable. They’re also inexpensive, so don’t be afraid to throw them away when they get really soiled.
  5. Buff the haze away with microfiber. A quality microfiber towel, like the Cobra Indigo Polishing Cloth, will buff your paint to a stunning shine as you remove the wax residue. The static-charged, woven fibers grab wax residue so there is less dusting, if any. Microfiber does not shed lint and the tiny, manmade fibers polish the paint while you buff. Rotate your towel frequently to reveal a clean side. Keep an extra Miracle Towel lying around in case the first one becomes caked with wax.
  6. If you do get streaks or an uneven shine, it’s easily corrected with a quick detail spray. Mist the surface with Wolfgang Instant Detail Spritz or Pinnacle Crystal Mist Detail Spray and buff away the problem.
Machine Application
  1. Select a foam finishing pad to apply wax. This pad is soft and absorbent, but firm enough to withstand the pressure of the machine. It’s perfect for any type of wax, even paste wax. A Lake Country gray finishing pad is shown to the right.
  2. If you are using a paste wax, spread it onto the pad like you’re buttering a piece of bread. You can turn the jar of wax upside down and slide the wax out into a plastic sandwich bag to rub it onto the pad, or you can use a clean putty knife. If you’re using a liquid wax or sealant, dispense three 3” lines of wax around the edge of the pad.
  3. If you’re using a liquid wax or sealant, press the polisher to the paint and spread the wax over a panel before turning the machine on. This will lessen the likelihood of splatter.
  4. Set your dual action polisher to a maximum speed of 3. Check the label of your particular wax for specific directions, but generally this is the fastest speed you need to apply wax. Spread the wax over the panel until it is evenly covered. Turn off your machine before lifting it off the paint.
  5. Buff with microfiber. Again, the Miracle Towel is your best friend. Some products allow you to apply wax to the entire vehicle before buffing, but many do not. If your wax does not, buffing by hand may be most efficient. If your wax can be applied to the entire vehicle before buffing, you might prefer to buff by machine using a microfiber or terry cloth bonnet over a lambswool pad for cushioning. Microfiber doesn’t shed lint like terry cloth can, but the choice is up to you.
Concours Tip
If you really want to amplify the shine, apply a layer of carnauba over a layer of sealant. The sealant will create a glossy, hard coating while the carnauba wax will enhance the depth and dimension of the paint. A popular combination in the forums is Klasse All-In-One under Souverän.
Glossary of Terms
  1. Wax – a protective coating usually made from natural carnauba wax and polymers that provides a deep, reflective shine.
  2. Sealant – a completely synthetic blend of polymers that provides long-lasting paint protection and shine.
  3. Bonnet – made from terry cloth or microfiber, it fits over a lambswool pad on a dual action polisher for buffing purposes.
  4. Dual action polisher – the head moves in two ways; it spins like an orbital and it oscillates. The motion is often described as jiggling. A DA polisher, like the Porter Cable 7424, will greatly improve the appearance of paint imperfections with minimal risk of burning the paint.
Low end paint ball gun FS nitro_freak1 Miscellaneous Stuff For Sale 5 02-01-2009 01:32 AM
second battery apply for me? aturcotte127317 General Car Audio Discussion & Questions 17 11-30-2008 09:01 PM
Trailblazer paint schemes bumpin buick Off Topic Chat 15 11-28-2008 12:06 AM
Chevy paint color question. RE_Gawker General Automotive Chat 7 11-03-2008 05:52 PM
