Lanzar Opti1532d TSP's after 2 hours Xmax @ Fs - Car Audio Classifieds!
Old 12-04-2010, 11:50 AM
Audio_phill's Avatar
Too Busy to be here
0/11 sssss2296
Feedback Score: 23 reviews
Default Lanzar Opti1532d TSP's after 2 hours Xmax @ Fs
Re = 4.3919 ohms
Fs = 26.5279 Hz
Zmax = 33.0967 ohms
Qes = 0.7747
Qms = 5.0634
Qts = 0.6719
Le = 3.4109 mH (at 1 kHz)
Diam = 323.0880 mm ( 12.7200 in )
Sd =81984.4529 mm^2(127.0762 in^2)
Vas = 56.3466 L ( 1.9899 ft^3)
BL = 24.0075 N/A
Mms = 609.9517 g
Cms = 59.0119 uM/N
Kms =16945.7246 N/M
Rms = 20.0788 R mechanical
Efficiency = 0.1276 %
Sensitivity= 83.0759 dB @1W/1m
4 net sealed looks good.
EBP is 34.4 so I dont recommend vented if you want it to sound as good as it's capable of!
Bought From: Funky Waves, Realbeach, Farmacist Louisiana_CRX, Lingerfelt, ciaonzo, SPY (X2), tristanmay, bigbassjoel, Sound_Around, Good Times
Sold To: alfabit1, Sound_Around, jonalford2087, woodels420, pangullo, chico305, ciaonzo, darkkon, faessle, UNDERGROUND_BUM, JCJR, adrian1185, fast306stang, tristanmay, biggen_bd, mwerling1212, HiloDB1, statonburrell
Traded With: HiloDB1, kn0wledge000, ciaonzo, tristanmay, Jh8909, fritosaregood
Old 12-04-2010, 11:59 AM
Too Busy to be here
0/11 sssss2296
For HT guys, Cross these low (sub 60Hz) and give it 15 cubes @ 13.75Hz and enjoy +/-3dB response of 12Hz to 50Hz... yes, I said 12Hz.
If you are a knuckle head and dont care what the sub wants and just have to vent it and use it in a car in improper volume. Might I recommend 4 @ 20Hz for a +/-3dB from 21Hz up with a 2dB slow peak from 37Hz to 44Hz, I'm using the -1dB as F3 to keep bandwidth within a +/-3dB range.
2 x 4" nominal diameter ports 36.5" long should give you a pleasant vent mach as well as an easy to build port system.
Old 12-05-2010, 07:52 PM
Too Busy to be here
0/11 sssss2296
Heres a fun pic, for reference, the red crescent on the dust cap is 3.875" in diameter
PG xmax 10 dacheatham Wanting to Buy (WTB) 0 11-19-2010 03:28 PM
Xmax How much is needed? sqonly Sound Quality Area 63 11-18-2010 07:42 AM
TSP's for Soundstream XXX 15 Audio_phill Tutorials & Quick References 3 09-14-2010 10:17 PM
[SOLD] Lanzar OPTI1532D **Mint** SundownAudioNY 15" Subwoofers 5 03-22-2010 10:53 PM
