How to prep fibegrlass for paint? - Car Audio Classifieds!
Old 05-11-2011, 09:29 AM
0/11 ssssss468
Default How to prep fibegrlass for paint?
Did these 2 yesterday for my tweeters.
First secured it with plumber's putty so i don't have to worry about tweeter pod moving a bit and then fiberglass to secure it all the + make it seem like one solid piece.
What do i use on top of fiberglass that would be easy to apply and sand?
Areas are small and "curve-y" all around
Old 05-11-2011, 09:33 AM
0/11 sssss2011
Feedback Score: 61 reviews
you can either use a mixture of resin and body filler or just body filler depending on how confident you are of the strength of the resin you have now. for paint you'll need to make sure the surface is as smooth as possible. probably use 120 grit than 200 grit than maybe 400 or 800 grit.
Old 05-11-2011, 09:54 AM
0/11 ssssss468
There's really not much of a need for (more) strenght in this case so body filler will do.
Now u're talking about any brand/make/model filler they sell in every AutoZone, Home Depot, Lowes....?
Old 05-11-2011, 11:01 AM
0/11 sssss2011
i personally use 3m products. the lightweight 3m body filler is ~$20-24/gallon and i've found that it's about as good as Rage Gold. the big difference being price, I can't get Rage Gold for less than $40+/gallon. I just can't justify the difference of $15 as they are about the same to work with. the Rage does same a bit easier and does bond a bit better. try a paint supply store.
Old 05-11-2011, 11:56 AM
0/11 sssss3842
i have used the Bondo brand as well as the Evercoat Rage Gold. The Rage Gold was alot easier to work with but its a good bit more expensive. i can get it for 35 a gallon but your not gonna need a complete gallon for those. a quart will do.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 05-11-2011, 12:27 PM
CLNFREAK's Avatar
0/11 sssss1788
Feedback Score: 23 reviews
ever coat rage extreem or regular rage
you will never use bondo again after you use it
MAY 8 2009 ask me about that day !!!!
SUBS (2) 12" DC LVL 5
SUB AMP 1100.1
MIDS AND HIGHS AMPS 2 EXL 400.4
BATTS NSB group 31, XS power d3400
SINGER ALT 350 AMP
TEAM DC
DCSOUNDLAB.COM
SINGERALTERNATORS.COM
Old 05-11-2011, 12:41 PM
LunchboxCritter's Avatar
Disco Biscuit
0/11 sssssss43
Duraglas is nice filler also.
-LunchboxCritter-
Old 05-11-2011, 12:56 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
evercoat FTW. And what did you do to help the glass stick to the plastic? Looks like you just layed up on top.
Old 05-11-2011, 01:12 PM
0/11 ssssss468
Sanded it with the biggest grid i had (don't know the number but that thing was more then enought lol, it was more like cutting that plastic rather then sanding lol) and cleaned it with acetone.
Old 05-11-2011, 01:22 PM
Ja Marcus
0/11 sssss6975
I have done it that way myself. It may or may not hold. You really need to use a plastic bonder to get it to stick for sure. But that stuff is expensive. Not to mention you need a special gun to do it with.
I would just lay a thin coat of filler and knock it down with 36grit. Then sand it out with 80-120 to get the scratchs out. Then a couple coats or high build and more sanding. After that primer sealer and a coat of paint. Wet sand up to 500. Then 8-10 coats of clear. Wet sand that to 2000 and buff.
Car Paint andes11 Off Topic Chat 25 12-06-2010 01:52 AM
deadener metal prep caps Sound Deadening & Fabrication 10 11-16-2010 02:53 AM
How to prep for recone - 13av2 basket Robert_J (Fix My Speaker) 3 07-19-2010 12:06 PM
Sound deadener prep? alvitae General Car Audio Discussion & Questions 12 02-05-2010 09:59 PM
$10,000 paint job bones22 Off Topic Chat 52 09-07-2009 12:45 PM
