"Box rise" and why not to worry - Car Audio Classifieds!
Old 06-13-2011, 05:45 PM
surreal's Avatar
0/11 sssss2489
Default "Box rise" and why not to worry
I see a lot of people thinking that if their "rise" was less theyd be hitting better scores or that its hurting them - not always the case.
"Box rise" is natural as the enclosure and speaker have their own impedance profiles. Take FS for example. The woofer is at a very high impedance yet output doesnt magically drop 500% or something.
Take for example this enclosure:
You could say the "tuning" is around 36hz physical. It is a D4 driver in parallel. At 38hz it is just over 3ohm. At 40, 4.5 ohm, 47hz, 17ohm, even at 55hz its still at 4.5ohms before the impedance peak goes back down.
Now of course depending on the way you design your box you can shift the impedance curve to get the most physical power out at a certain frequency. But the point is, if youre getting high "rise" dont worry about it. It is perfectly natural and the woofer gets more efficient in these areas.
For example, you burp a 143 at 47hz there when impedance is crazy high. Then you go down just a few hz to 40 where its a quarter the impedance it was at 47, and you burp a 142. If you clamp them both, chances are youll see more physical power at 40hz, even though your score was worse. Why? Impedance rise happens and the woofer naturally compensates for it.
Many people try to burp with daily boxes and get scared when they see crazy rise. If youre shooting for SPL in a daily box in the first place, the little difference this will make wont hurt you.
If anything is wrong here let me know. This is currently my take on it. For all out SPL yes you can shift the box parameters to have a low impedance at burp and get the most power. But this is a practical write up for most who arent extreme competitors.
The Following 12 Users Say Thank You to surreal For This Useful Post:
Blockbeata09 (06-13-2011), crucial24 (11-01-2017), D810boy (07-03-2011), dat517boi (06-30-2011), enemyofsilence (12-13-2016), hughesc9393 (07-19-2011), jt_buck (06-14-2011), Lnh (06-30-2011), my_stealth21 (06-14-2011), resko1 (06-14-2011), sho412 (07-27-2011), TreyE (10-16-2013)
Old 06-13-2011, 06:00 PM
mega fatty
0/11 sssss6008
i like the write up only thing i would add would be actual results from rise/ clamped power
i think taylorpro has a few examples that would be great in here to give the credibility of real world results
07 mazdaspeed3
rd d9 @ .5ohm
Old 06-13-2011, 06:04 PM
surreal's Avatar
0/11 sssss2489
Ive never really bothered and I dont have a meter worth mentioning.
Old 06-13-2011, 06:07 PM
mega fatty
0/11 sssss6008
right niether do i but im almost positive taylorpro has a few good readings from his "research" maybe hit him up to post a few in the thread
07 mazdaspeed3
rd d9 @ .5ohm
Old 06-13-2011, 06:49 PM
Ego Crusher
0/11 sssss1834
How would you go about shifting the curve so that you get minimal rise at your peak frequency for maximum spl output?
06 trailblazer ss (Ego crusher)
Texas speed forged 408,custom cam, stalled
hp numbers coming soon
focal 4.160,fosgate coax in rear doors
popcorn sounds 6k ,2 sundown sa15, in a 6th
Old 06-13-2011, 07:17 PM
HACKMUNCH's Avatar
0/11 sssss3892
port the box at your peak frequency. box peaks sealed at 50 hz, port it there and watch what happens.
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 06-13-2011, 09:48 PM
0/11 ssssss112
say you run a 1ohm amp @.5 ohm it should still effect the impedence rise across the entire playable range? in which case the sub would "see" more power across this range? ie. the impedence spike would be less there by increasing power and as long as its clean and the sub/elec can take it?
Old 06-13-2011, 09:55 PM
Eric B's Avatar
LowBlowBro
0/11 sssss2140
Ive been saying this for some time... People get so mad over it. Its stupid.
The Following User Says Thank You to Eric B For This Useful Post:
Josh Wahlie (06-14-2011)
Old 06-13-2011, 10:36 PM
Josh Wahlie's Avatar
< Pic from my build log!
0/11 sssss3196
Love the right up man.
Custom Box Builder (Ships all over the USA)
Shok Industries Dealer
Old 06-14-2011, 09:52 AM
Ego Crusher
0/11 sssss1834
Well my suv peaks at 43hz so I should tune the box for that. Also should the box be on the bigger side or the smaller side or does it even matter?
Amp and box rise...? SPL_II General Car Audio Discussion & Questions 9 07-02-2011 01:04 AM
fighting with box rise constantprojects Enclosure Discussion & Design Construction Help 50 04-10-2011 09:30 PM
FREE BOX! 18" Box, dual 6" aero port snb778 Wiring, Electrical & Other Installation Equipment 17 11-09-2010 08:12 PM
box rise luises14 General Car Audio Discussion & Questions 3 05-18-2010 09:28 PM
Single 12" sub in good box vs. 2 12" subs in box that's a little too small? MisterTedster General Car Audio Discussion & Questions 6 01-07-2010 02:01 AM
