How to: Install a drop in recone assembly - Car Audio Classifieds!
Old 07-12-2011, 03:14 PM
resko1's Avatar
<<< atomic at7000.1d
0/11 sssss2134
Feedback Score: 21 reviews
Default How to: Install a drop in recone assembly
These are older but good. Ill have newer ones up soon on how to build from parts.
YouTube - &#x202a;How to: Install a drop in recone assembly part 1&#x202c;&rlm;
YouTube - &#x202a;How to: Install a drop in recone assembly part 2&#x202c;&rlm;
http://www.youtube.com/watch?v=pKySb...eature=related
YouTube - &#x202a;How to: Install a drop in recone assembly part 4&#x202c;&rlm;
just an old fart
The Following 2 Users Say Thank You to resko1 For This Useful Post:
thel.t.d.supply (07-19-2011), xxxbasshead (07-12-2011)
Old 07-12-2011, 05:58 PM
thel.t.d.supply's Avatar
0/11 ssssss835
new build old equipment
Old 07-12-2011, 07:08 PM
resko1's Avatar
0/11 sssss2134
one thing i forgot to mention is basket cleaning. I used a new basket in these so it wasnt needed. But before i recone can be installed the spider landing and surround landing need to be clean. Free of any material or glues and if able to, stripped down to bare metal. You can use a palm sander or angle grinder but be careful not to eat into the basket. It can make the landing un even and it will be worthless.
just an old fart
Old 07-12-2011, 08:22 PM
0/11 ssssss835
do you recommend sewing the leads or does it just depend on the application... spl...sq...daily setups?
Old 07-12-2011, 09:09 PM
resko1's Avatar
0/11 sssss2134
the whole theory behind sewn leads is a design to reduce or eliminate lead slap on the cone at high excursion. Its entirely up to you if you wanna sew them or not. There's 2 methods. One is sewn with the rolls like as a sundown sa series, or one is sewn on top of the rolls like psi does. Both ways will work but sewn on top seems to be a little more forgiving to the novice.
just an old fart
Old 07-12-2011, 09:21 PM
0/11 ssssss623
also watch your fingers if using a angle grinder!! lol
Old 07-18-2011, 11:46 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
how do tc sounds do theirs? It looks like melted solder on the spider. Kinda like a printed circuit board. Just based off of looks it would seem they couldn't take big power.
Old 07-19-2011, 11:41 AM
0/11 sssss2030
Feedback Score: 22 reviews
They put the lead between the 2 spider half's and then hot form them together.
Old 07-19-2011, 11:42 AM
0/11 sssssss12
thankss, now i know how to recone!
Old 07-21-2011, 06:56 AM
resko1's Avatar
0/11 sssss2134
Close tommy. we actually talked about this and you were correct. Some companies "adhere" The tinsel to the spider before it is thermoformed. TC on the otherhand has it integrated into the spider or "interwoven" before thermoforming or compression molding. And that was one of tc's weak points was the leads. Not so much how it was done but the insufficient gauge of wire used.
just an old fart
FS: 12" Top Assembly drop in kit for TC 3HP motors Pillow Speaker Accessories & Parts 10 06-05-2011 11:25 PM
I need a drop in recone kit budowens83 (Fix My Speaker) 1 12-01-2010 12:49 PM
drop in recone? Dunbar91 General Car Audio Discussion & Questions 0 07-01-2010 09:12 PM
[WTB] TC LMS-4000 Recone / Top Assembly Biggy Wanting to Buy (WTB) 3 06-28-2010 02:45 AM
18" drop in recone RidnClean Speaker Accessories & Parts 35 06-08-2010 10:38 PM
