DD 9500F
Pole O.D. 2.98"
Pole I.D. 1.12"
Gap O.D. 3.30"
Pole height (top plate to top of pole only) .45"
DD 9500G
Pole O.D. 2.98"
Pole I.D. 1.375
Gap O.D. 3.30"
Pole height (top plate to top of pole only) .875"
DD 9500H Supercharged
Pole O.D. 2.90"
Pole I.D. 1.168"
Gap O.D. 3.30"
Pole height (top plate to top of pole only) .792*
*neo ring is .392" and aluminum ring on top of neo ring is .40"
AQ HDC3
Pole O.D. 2.95"
Pole I.D. 1.22"
Gap O.D. 3.39"
Pole height (top plate to top of pole only) 1.118"
AB HD
Pole O.D. 2.95"
Gap O.D. 3.33"
---------------------------------------------------DD 9515 (AND 95Z) COIL MEASUREMENTS----------------------------------------------------------------------------------------------------------------------------------
DUAL 2 COPPER COIL (STANDARD 9515 COIL ON STANDARD CONE ASSEMBLY)
I.D. - 76.75mm
O.D. - 82mm
FORMER HEIGHT - 125mm
WINDING HEIGHT - 45mm
DUAL 1.5 ALUMINUM COIL (STANDARD 95Z COIL OPTIONAL 9515 UPGRADE0 ****THIS IS ONLY THE MEASUREMENTS FOR CARBON FIBER CONE ASSEMBLY****
I.D. - 76.6mm
O.D. - 82.25mm
FORMER HEIGHT - 135mm
WINDING HEIGHT - 57.75mm
AUDIOQUE HDC3 COPPER (ROUND WIRE) COIL DUAL 2
I.D. - 76.65mm
O.D. - 83.5mm
FORMER HEIGHT - 114.25mm
WINDING HEIGHT - 50mm
AUDIOQUE HDC3 ALUMINUM (FLAT WIRE) COIL DUAL 1
I.D. - 76.20mm
O.D. - 83.25mm
FORMER HEIGHT - 115.65mm
WINDING HEIGHT - 53.0mm
All of the poles have round vent holes, the 95H motor has no cooling vents in the top plate like the G motor does, the pole I.D. is slightly smaller on the H than the G. No pole plugs in any of the motors.
