SPY's Lincoln LS build - Car Audio Classifieds!
Old 08-16-2009, 07:31 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Default SPY's Lincoln LS build
Well this has been going on for a while and will probably never be done since I change things so often but I figured with the new section I would start a thread here.
Link to discussion thread:
SPY's Lincoln LS build log discussion thread. - Car Audio Classifieds
Car: 2002 Lincoln LS V8
Electrical:
250 amp Mechman Alt
2 runs of Knukonceptz Kolossus Fleks 1/0 from alt to batteries
Kinetik HC 1800
Kinetik HC 2400
Knukonceptz Kolossus Fleks 1/0 and 4g from batteries to amps
HU and processing:
Alpine IVA-W505
Alpine PMD-B200 - Blackbird II Nav
Alpine SIR-ALP1
Alpine KCE-422i
Alpine PXA-H701
Alpine RUX-C701
Audio Control Epicenter
Front Stage:
Dynaudio System 362
8" woofer mounted in doors and 3" mid and 1.1" tweets in custom fiberglass kick pods
Rear Stage:
None
Sub Stage:
I will be conducting my own 15" sub comparison, this will be more of a SQ based comparison and will be judged by my personal listening taste and not by what #'s it puts up on the TL, although some TL testing might be done also.
Current list of subs to be tested are:
15 RE Audio XXX (07 version)
15 RE Audio XXX (05 version)
15 Eclipse Ti
15 TC-3000
15 TC-5200
15 TC LMS Ultra
15 RD Audio Heavy Weight
15 RD Audio Alpha V3
15 Cascade-Designs Omega
15 Oz Power Series
15 Sound Stream XXX
Sub enclosure:
Custom SPY Design Audio box, [email protected] with a single 6" aeroport
Amps:
Front Stage - Sundown SAX-100.4 running [email protected] to the Dynaudio 3-way comps
Sub Stage - Sundown SAZ-3000D
/ CAAA Member #2 /
Old 08-16-2009, 07:38 PM
SPY SPY is offline
0/11 ssss10192
The car:
/ CAAA Member #2 /
Old 08-16-2009, 07:39 PM
SPY SPY is offline
0/11 ssss10192
Cleaning up some wiring and pulling RCA's out and running wires for the H701, C701, Epicenter and Sundown bass knob
/ CAAA Member #2 /
Old 08-16-2009, 07:49 PM
SPY SPY is offline
0/11 ssss10192
Running power from alt to the batteries in the trunk
/ CAAA Member #2 /
Old 08-16-2009, 07:50 PM
SPY SPY is offline
0/11 ssss10192
Installing the HU
I will be removing the trim piece and touching up the paint before this is over.
/ CAAA Member #2 /
Old 08-16-2009, 07:52 PM
SPY SPY is offline
0/11 ssss10192
Building the fiberglass kick panels
/ CAAA Member #2 /
Old 08-18-2009, 12:15 PM
SPY SPY is offline
0/11 ssss10192
Laying out the H701, Epicenter and Sirius unit and 2 more fuse holders
Test fitting the drivers side kick pod before covering it.
/ CAAA Member #2 /
Old 09-03-2009, 11:18 PM
SPY SPY is offline
0/11 ssss10192
Test fitting the passenger side kick
Kicks carpeted, speakers mounted and everything installed.
/ CAAA Member #2 /
Old 09-03-2009, 11:34 PM
SPY SPY is offline
0/11 ssss10192
Pulling out the old Kicker 8" mids and installing the Dyn 8's
The old kicker 8" and 2 layers of edeadv1 on the doors, hoping to replace the deadener with something better soon though.
Removing a bracket that was in the way of the new setup.
Some trimming was required to get enough mounting depth.
Just fits behind the door panel, grills were installed to protect the speakers
Passenger side was the same thing.
MDF baffles were covered in bedliner spray to protect them from water.
/ CAAA Member #2 /
Old 09-03-2009, 11:38 PM
SPY SPY is offline
0/11 ssss10192
Wiring up the H701, Epicenter and amps.
Trimming the mounting bracket for the C701 so it will fit in my dash.
/ CAAA Member #2 /
SPY's 2 12" Isobaric build SPY Off Topic Chat 117 08-16-2010 07:33 PM
2002 Lincoln LS build log SPY Off Topic Chat 23 07-15-2009 02:58 AM
Patrick's 2000 Lincoln LS Build Log Patrick Simmons Build Logs 322 07-12-2009 08:29 PM
Spy's [email protected] build SPY Off Topic Chat 18 06-25-2009 10:31 PM
