Fi Q 10 Bandpass - Car Audio Classifieds!
Old 10-19-2013, 03:10 PM
0/11 sssssss40
Default Fi Q 10 Bandpass
Hey guys started a new box for my truck today, it will house 2 Fi Q series 10's dual 2 Ohm. The box is bandpass with a plexiglass top the ported chamber is 1.77 cuft net after sub and port displacement. The port is tuned @ around 42 Hz. The sealed section is .89 cuft total (not net). Outer box dimension are H:18.75" W:15" L:32". The sealed section of the box will have the subs cone facing up with a 3/4 removable plexi top and on the inside mdf I am using an oil based primer/sealer and will be painted a dark navy blue. (The port will get this treatment as well). The inside as well as outer side edge of the slot port was rounded by hand. The exterior edges will be 3/8 roundover using a router, as well as the port opening edges.
Old 10-22-2013, 05:48 PM
0/11 sssssss40
Hey guys just posting an update, I i have ordered the subs with a green dustcap, the cooling option and dual 2 Ohm. Here is the port and rest of the box being made as well as bondo, sanding, and 1st coat of resin
Old 11-05-2013, 03:35 PM
0/11 sssssss40
little update, not much has happened one sub should be here thursday sometime i purchased all my 1/0 cable to do a run from front battery to back acc batts. need to order two more fuse holders, a drag style manual battery cutoff switch, two battery boxes, some 1/0 waterproof grommets, and the amp and should be ready to roll. Future things to come are an Alpine headunit (Alpine CDE-147BT) to be exact, with the small inline amp for speakers. Does anyone have any ideas on how to hold the box down and still be able to use it as a center console?
Old 11-07-2013, 12:45 PM
0/11 sssssss40
Santa brought one present today
Z V.2 18 Bandpass help 1ndatrunk (Sundown Audio) 12 01-15-2012 06:08 PM
bandpass help bottlefed1 Enclosure Discussion & Design Construction Help 1 07-10-2010 03:50 PM
Bandpass basshead08 Enclosure Discussion & Design Construction Help 5 03-17-2010 04:09 PM
Bandpass help bdufner Enclosure Discussion & Design Construction Help 7 09-05-2009 08:50 AM
bandpass? basshead08 General Car Audio Discussion & Questions 16 08-03-2009 03:45 AM
