blfuller123's 2001 Jetta TDI build - Car Audio Classifieds!
Old 09-19-2009, 01:41 PM
blfuller123's Avatar
0/11 ssssss223
Default blfuller123's 2001 Jetta TDI build
I have had this car for a couple of years now and have had a couple of smaller boxes in it, but now I am going to go a little bigger. I dont plan on competing, but I would like to put a meter on it and see what it will do.
I got in on the pre-sale for the RD 3250 v2 so that is the amp that will be running my subs. I got Patricks RD Alpha 12s and that should work good.
The head unit I use is an Alpine CDA 105. I am happy with it because it is practical for me.
I also run an older clarion pre-amp. I have had it for years.
I replaced the front and rear speakers with some boston acoustic components about 2 years ago. They still sound great and I will keep them. They are powered with my factory monsoon amp (no pictures).
The last week or two, I have started working on the car again. I have recently finished up the big 3 and run a single 3/0 back to the trunk that will tie into the c&d batteries.
I just have the factory 120 amp alternator right now but will be upgrading it as well.
Today, I got the old box that was in the trunk torn out. The new box will be 4.65 cu ft net, tuned to 45hz with 50 sq inches of port. The subs and port will fire forward and will be sealed from the trunk. I am considering having the port fire through the rear deck.
I might have all week to work on the car before I travel out of town again. Here is where I am at now.
Here is the radio/pre-amp
Here is the wire I used for the big 3 and the run to the trunk
1/0 and 3/0
3/0
Here is the battery after the big 3 were done. I want to get some custom terminals fabbed up to replace these.
Here is the trunk today after tearing out the old box that was in it.
Ebay Reference: beefller12 feedback 500+ 100% Positive
Scammed by Demonik Audio Tim Roy (Boomin SPL Sound Xtreme)
wiring harnesses, 2001-04 mazda Nudels Wiring, Electrical & Other Installation Equipment 4 09-10-2010 10:55 AM
Girlfriends Jetta build Ryan1126 Build Logs 49 08-25-2009 03:13 PM
S10 Extreme 2001 Any Info? thedukey42 General Car Audio Discussion & Questions 4 07-14-2009 11:02 AM
18" havoc in a Jetta? lunari General Car Audio Discussion & Questions 10 07-11-2009 04:26 PM
2001 Cadillac DeVille Build Log Bigboiii Build Logs 11 05-25-2009 01:11 AM
