xcort wall build - Car Audio Classifieds!
Old 02-22-2010, 11:31 AM
mega fatty
0/11 sssss6008
Default xcort wall build
95 ford excort
18 apxxd2 16cf wall
rd d9
2 stinger sp1700's, 3 spv70's
170amp alt
well alt and one sp1700 are already in, yeah i got a sp1700 up front, and i have one run of 1/0 to the back batt bank
box build starts NOW!
box 16cf internal, interchangeable ports, 320sq" of port tuned to 65, 180sq" tuned to 39
Tear down
^potential problem
the new wing!
Old 02-22-2010, 04:09 PM
mega fatty
0/11 sssss6008
the monster drill bit!!!
rear batts going here^
Old 02-27-2010, 12:46 AM
mega fatty
0/11 sssss6008
just an update, the rod will be cut down
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-08-2010, 02:49 PM
mega fatty
0/11 sssss6008
lil update from today that is just a layer of resin i will glass it in the next couple days
the sander it worked great!
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-23-2010, 02:09 PM
mega fatty
0/11 sssss6008
Originally Posted by tymoto21 View Post
finnished pics, i couldnt get a vid, having problems with my car idleing.... hope to fix that tomorrow or i will get a driving vid.
i think ima put a strobe or something to light up the box
and that is the daily port, the other port is 12"x27" and 3" long, it hits the highs real good! hopefully will do good on the mic
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-31-2010, 02:50 PM
mega fatty
0/11 sssss6008
battery bars are done and in, amp is blown going out to db-r tomorrow, should be good when it gets back!
and the burn mark on the amp (right around the little red cap)
07 mazdaspeed3
rd d9 @ .5ohm
Jacob's Wall Build Log sundownz (Sundown Audio) 114 07-12-2011 07:08 PM
92 s-10 ex. cab wall build s10 with 4 15's Build Logs 86 09-27-2010 04:11 PM
*Updated 7/11*Wall is in..The 2k build!! Crazy Chevy pt. 3 forceww Build Logs 419 08-07-2009 12:11 AM
Frontier kinda wall, 2 AQ SDC 15's build log Goindef154 Build Logs 26 07-06-2009 02:40 AM
2000 mercury cougar wall build basebalz13 Build Logs 81 02-07-2009 10:33 PM
