marcotheclepto's sa8 4th order BP elf mini amp build log for ex co worker - Car Audio Classifieds!
Old 01-22-2011, 12:08 PM
Prohibited Sellers/Buyers
0/11 sssss1326
Default marcotheclepto's sa8 4th order BP elf mini amp build log for ex co worker
basic design. .6 sealed 1 ported to 46 Hz with a 4 inch round port (home made)
some 45's will go into corners
Uploaded with ImageShack.us
the sub beside my eclipse sw8102dvc
the amp: elf 500w mini amp (and power wire)
some of the wood cut up
some fiberglass on the port (made from 4 inch mailing tube i got from work)
starting on the home made flare
more progress on it.
going together...
resined the inside.
wire and ("custom" terminals in) haha the old nut and bolt with washers \
paint has been added to that 45 you can see through the port, didnt snap a pic of that.
last few pics i snapped, carpet going on
test fitting amp over the stock battery location
and box in the trunk
amp did really well from what i could tell. didnt heat up, pushed the sa8 easily, and sounded pretty good overall.
The Jeep : 4th Order No-Wall Build sundownz (Sundown Audio) 30 02-14-2011 05:44 PM
4th order build for fun Ajax_6154 Build Logs 55 11-22-2010 02:38 AM
ABC 4th Order Build RidnClean Build Logs 13 12-26-2009 07:42 PM
BIGCs Mini Build!! BigC-Expo Build Logs 20 11-29-2009 11:09 AM
Ohio Burger King Worker Fired For Bathing In Sink Patrick Simmons Off Topic Chat 3 08-14-2008 02:14 PM
