1994 Dodge Stealth R/T turbo - Car Audio Classifieds!
Old 05-02-2011, 10:53 AM
0/11 ssssss155
Default 1994 Dodge Stealth R/T turbo
I decided that I would bring over the Pioneer equipment that I had in my Saturn, this meant I have 5.1 DTS and Dolby Music II available. So I start with the biggest stealth challenge, getting my center channel without just putting Pioneer's center speaker pod on the dash.
This is what I did with my Saturn and I hated how it looked. Sounded great, just looked too non OEM for my liking. I thought about installing my center channel into the center vents of my Stealth. I read about this being done on another 3S owner's Stereo page. So I spent the whole summer with them closed to see if I could do without them, I didn't miss them at all so I picked up another center vent piece and went to work.
The biggest problem was to find a speaker that would fit there and give the fullest sound possible. I based my driver selection with the Freq. response that the Pioneer speaker pod had, according to Pioneer the speaker pod has a Freq range of 140Hz ~ 30kHz.
I found a Tang Band speaker that has a Freq range of 150Hz ~ 20,000kHz, I figured that this would be close enough plus the shape of this speaker is what appealed to me the most. It's dimensions are 2"x3" with a cutout of 1-13/16" x 3-3/8". I ended up sanding the long side of the speaker flanges down to get them to fit how I wanted but I think I achieved success.
I started by cutting the duct of the center vent like so:
I removed the metal clips that lock this vent into the dash before I cut it in two. After sanding, sanding, and more sanding, I was able to squeeze these into the opening of the vent, it is almost a perfect fit. The grills of the vent lock the speakers from moving forward.
Here is a couple pictures:
I will use Gorilla tape to join the two pieces back together once I get the back half of the vent sealed off and stuffed with Poly fill . I will also take non-drying modeling clay to seal off the backs of the speakers from the front.
Here is a rear shot:
Once I get baffle sealed off, I will wire them up in series and tape the two pieces back together. The best part is this will still remove like it should and I can replace the speakers should I blow them.
I sealed the speaker baffle with clay on both sides, I managed to form the clay on the front side to make the front opening shaped like a horn:
Back side:
Then I took the vents out and covered them. So here is the finished product:
VERY "stealthy" right?
At this point I realized that I can not access the retaining clips behind the vent grills to remove the center vent in case I ever need to service the speakers, so I tried installing my center channel without them, turns out that the vent is lodged in the very good and I was able to remove the metal retaining clips.
From there I cut about a 1/2" off the back side of the duct. I didn't want the speaker terminals interfering with the air ducts. I then cut a plug for the rear from a plastic cutting board, glued it into place and added clay to the joint and surface of the duct to reduce any resonance that may have happened otherwise.
You can also see the nuts & bolts i used to make my speaker terminals. I wired the speakers together in series making the Ohm load 8 Ohms and 30 W RMS, I will be powering 100 W RMS to them, I like head room.
Stuffed some poly fill into the enclosure and taped the two halves together with Gorilla tape. Color the "-" nut with a Sharpie this is what the back looks like:
I have been able to audition my creation by hooking it up to my home theater right channel. Gave it a listen for a little bit sounded really good, actually it sounded better than the KLH speaker that I am using for my home theater. Noted this for a possible set of H/T speakers. So I know that this at least sounds decent at 80Htz and above because that is what my H/T speakers are x-over'd at.
I even have an Orion MaxBass to see if I can play around with the psychoacoustics to gain some bottom end, add the AudioControl DQS to the external processing, I THINK I should be able to make it sound acceptable.
Old 05-02-2011, 10:58 AM
0/11 ssssss155
Default Sound deadening
With the weather finally starting to warm up enough, I am able to start working on this project again.
With the hatch plastic out for the installation of my rear strut bar, I decided to start to sound deadening the hatch and hatch floor.
I went with the 25% coverage approach in order to save weight.
I am undecided if I want to go the CCF and MLV route yet in the hatch, the MLV adds allot of weight...like 1lbs per square foot.
Anyways enough of explaining my decision.... on to the pictures:
As you can see I have more than 25% coverage on the hatch floor....oh well
Old 05-02-2011, 11:14 AM
keifersracing's Avatar
Team Roto Rooter
0/11 sssss1407
looking good
Old 05-02-2011, 11:20 AM
0/11 sssss1330
Why do you want a 5.1 system in your car? Do you watch a lot of movies in it or something?
Got any pictures of the Saturn that we can use to compare?
2010 Volkswagen CC
HRE Wheels | Nitto Tires | Solo-Werks
Ground Zero | Ampere Audio | Juicebox Battery | AudioControl | KnuKonceptz
Old 05-02-2011, 01:06 PM
0/11 ssssss155
I went that route with the Saturn for show purposes, so it is equipment I already had in my possession.
Here is the Saturn:
2001 Saturn SC2 Build log (what it was)
Old 05-02-2011, 01:28 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
thats crazy....i see a Mitsu 3000gt that run around by me and looks almost the same in color!!! lol....i had to double check where you were from lol. Looks good bro! Stealths are nasty too....i mean that in a good way!!!
2013 Toyota Highlander
Build to come.....
Old 05-02-2011, 04:17 PM
Second Skin Rep Jon's Avatar
Vibration Consultant
0/11 ssssss412
Nice build thus far, really love the stealthy vent drivers! Definitely a build I'll be watching.
Old 05-06-2011, 12:18 AM
0/11 ssssss155
Default Amp rack
Just a small update, I figured out how to secure my amp rack without putting holes in the chassis of the car.
I attached these to runner boards to the car by using the plastic screw inserts that are used to hold the original compartments in place.
Now I have the joy of cutting up cardboard to make a stencil that contours to the trim AND my camel hump.
Old 05-06-2011, 12:20 AM
my_stealth21's Avatar
TC WHORE
0/11 sssss2110
Nice bro I have always loved stealths they are still my fav car not everyone knows about them I esecially love the 94-96 stealths I used to have a 92 always dreamed of owning a 96 pearl white twin turbo lol fat chance
Old 05-06-2011, 12:24 AM
0/11 ssss31247
Giving up you center dash vents for the center channel... that's more committed than I've ever been.
Love those TB speakers! I used the same set on a buddy's truck for his center channel.
Good stuff so far.
Would like to see your old cars build also someday!
madscientist (08-29-2012)
1994 Explorer Juice0723 General Car Audio Discussion & Questions 0 04-27-2011 04:51 PM
My 1994 Dodge Stealth R/T Twin Turbo 2fnloud Member Rides & System Pictures 50 03-01-2011 05:24 PM
autotek stealth xjoeyc23x General Car Audio Discussion & Questions 12 04-05-2010 10:36 PM
WTB: 4th Gen Camaro Stealth box bmw2k10 Wanting to Buy (WTB) 0 03-22-2010 06:40 PM
