MCarmers Highlander Sundown Build - Car Audio Classifieds!
Old 08-27-2011, 12:04 AM
mcarmer's Avatar
0/11 ssssss293
Default MCarmers Highlander Sundown Build
Alright ive had my truck together for a little bit now just been lazy and havent posted up pics of the build yet.
Vitveet from CA.com and myself did the build, I was pretty much there as a helping hand on my own truck.
I originally planned on doing 6 SA 15's on 1 Sundown SAZ4500 with a bunch of other stuff of course.
Ended up doing 4 SA 15's because at the time i didnt want to lose my backseat, and didnt have enough space for 6 in the cargo area, HELL dont even have room for 4 SA 15's there suffocated right now and the box isnt even tuned correctly.
The HL is back up and driving, planning biggest build for it since the Saturn was involved in an accident and totaled on 10 December.
MY REFS: See my I Trader above. CA.com MCarmer EBAY MCarmer18
Old 08-27-2011, 12:09 AM
0/11 ssssssss9
How many cubes is it and whats it tuned to?
Old 08-27-2011, 12:11 AM
mcarmer's Avatar
0/11 ssssss293
Already plan on losing the backseat soon, building the truck up structurally like stripper pole, windhshield bracing, roof bracing, floor bracing and other things. Then Im going to get Teamnemesis DJ build me a wall behind the front seats for as many 15's as i can fit in the truck, that will determine how many more 4500's i get and how i split the subs up on the amps.
This will all be part of a different build later on, THIS SUNDAY DJ will be looking at my truck and telling me what my options are and what he can do to get this thing into the mid 150's or higher on music.
Old 08-27-2011, 12:12 AM
mcarmer's Avatar
0/11 ssssss293
Sub box has 2 6x17long Aero ports and is roughly 7.5 cubes, sits in cargo area only. The REAR seats fold up and INTO the sub box...See pics.
This box is too small for 4 15's no way we could fit 6 15's, box is not what i want so going to redo the truck and lose the back seat to gain a ton of room.
Center console box holds the 2 new SA-8s V1.75's, powered by the DDC6B amp 550x2.... Box was way too big so to hold me over till the wall/clamshell whatever it happens to be gets done. I put a ton of expanding foam in the box to kill the itnernal space and increase the power handling on the SA8's and they actually play alot better now.
ONE OF MY ISSUES IS THE BOX IS NOT REALLY TUNED TO ANYTHING LOL. I was told by quite a few people the Aero ports are too close to the hatch so they arent doing anything. Also the box is WAY to small for the subs, and that the subs are cancelling eachother out because they are on different planes from eachother.
Old 08-27-2011, 12:15 AM
mcarmer's Avatar
0/11 ssssss293
2001 Toyota Highlander
Custom made REAR Coilsprings for struts, Added EXtra 900 pounds of load bearing to springs
22 Inch Helo H866 Black with Chrome inserts with Nitto NT420 265/35/22's
All tinted out, Vinyl on windshield
HID 6k kit low beams
Hids in interior and license plate
Sueded out headliner, took out stupid sunglass holder and all that crap
Sueded out dash pieces, Glove box and driverside under dash
ALL Pillar posts are Sueded out
Brand new factory black carpet in interior
Over 8 rolls of Sound deadener
A few buckets of deadener where theres no matt
DEADENED ALL DOORS,FLOOR, CEILING, REAR HATCH EVERYTHING.
Removed rear wiper motor hole in rear door got it Shaved, repainted factory paint and embedded Toyota emblem was filled in and shaved smooth!
Alpine CDA117 16GB Thumb drive for music/ cds skip
Custom Toolmaker Distro blocks made for MAIN Deka8a31 batt under hood
mcarmer's Avatar
0/11 ssssss293
MLA 14.7/15.3 Switchable With Charger option under hood
Ohio Generator 275A alt
ALOT of KnuKonceptz 100%OFC 0 GA wire.
-13 KnuKonceptz 300 Amp ANL fuse holders. 12 300 amp fuses & 1 160amp for the DD amp.
- 4 Runs of 0 to rear for POS wire fused at beginning and end of lines
- Double 0 Ga BOTH fused comin from Ohio Gen 275A alt + stock 4 Ga wire
- Double 0 Ga on ALL ground points under hood
- All 5 G31 Batts in rear grounded individually and neg's are all tied together also.
- All 5 G31 Batts in rear tied together through POS posts.
- All KnuKonceptz Krystal RCA's or better on a few parts
Pheonix Gold PLD1 Line Driver(For SAZ4500 voltage)
PAC Parts Voltage knob(SAZ4500 voltage adjustment)
Audiocontrol Four.1 Line Driver/EQ(For DDC6B amp voltage)
2 Stinger Blue LCD Digital Voltage displays(1 on the main battery & the other at the Sundown 4500 amp)
Old 08-27-2011, 12:16 AM
mcarmer's Avatar
0/11 ssssss293
Sundown SAZ-4500
4 Sundown SA-15's (2 extra sitting in house )
2 New SA-8 V1.75 subs in center console box
Digital designs DDC6B 550x2 for SA-8 subs
Alpine Type S Comp speakers in all doors, powered by Alpine HU(Plan on doing a big door build when i get Dj to do the big build)
First video was taken by OldBass40 at a event in Macon GA in Aug 2011. The other videos were taken by me or Vitas.(Vitveet)
System banging! - YouTube
If you don't want to look at the pics in the thread then you can click on this link and see all the build pics in my photobucket account.
HIGHLANDER AUDIO BUILD pictures by MCarmer84 - Photobucket
Imma do my best to put the pics from oldest to newest there maybe a group of pics that might be a little mixed up timeline wise.
Old 08-27-2011, 12:21 AM
mcarmer's Avatar
0/11 ssssss293
Old 08-27-2011, 12:27 AM
mcarmer's Avatar
0/11 ssssss293
Old 08-27-2011, 12:32 AM
mcarmer's Avatar
0/11 ssssss293
Build for 8 Sundown 8s Wes669 Build Logs 51 05-28-2011 03:23 AM
My little sundown build Vasilios Build Logs 10 10-10-2010 01:50 PM
my sundown build BASS14 (Sundown Audio) 21 03-07-2010 10:39 AM
The Sundown Passat Build Biggy Build Logs 13 03-23-2009 03:39 AM
