330 amp SINGER ALTERNATOR LIFETIME WARRANTY - Car Audio Classifieds!
Old 11-22-2011, 02:01 PM
Active Member
0/11 ssssss846
Feedback Score: 23 reviews
Default 330 amp SINGER ALTERNATOR LIFETIME WARRANTY
330 singer alternator for the 5.3L gm engines. i have it on my avalanche, will fit on denali, yukon, escalade, tahoe, silverado, etc.
200 amps at idle, 330+ 2000rpm
3 months old, LIFETIME WARRANTY (pay for parts, labor is free)
$420 SHIPPED OBO (no trades, unless you will give me your soul)
Old 11-22-2011, 05:21 PM
0/11 ssssss259
Originally Posted by obrien202 View Post
if only this was 16v
cant you just get a external regulator to make 16 volts
Old 11-22-2011, 06:24 PM
got160s?'s Avatar
0/11 ssss13630
If you talk to singer or if someone wants me to see about getting this to be externally regulated it wouldnt cost a lot.
Then all you need is a regulator then you have 16v!
Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast
Battery: 25 XS Power XP1000's
Sub Amp: 3 DC 9k's
Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order
Subscribe now! Prizes will be given away for every 1000 subscribers!
Old 11-22-2011, 06:25 PM
got160s?'s Avatar
0/11 ssss13630
Forgot to add this should do around 400 amps on 16v
Sub Amp: 3 DC 9k's
Old 11-22-2011, 06:42 PM
truespartan9584's Avatar
Team Ungodly Powers
0/11 sssss1524
Feedback Score: 50 reviews
2pin or 4pin
Old 11-22-2011, 07:42 PM
Active Member
0/11 ssssss846
Originally Posted by bambino9584 View Post
2pin or 4pin
im pretty sure its the 4 pin.
Old 11-22-2011, 07:52 PM
1loudyukonxl's Avatar
0/11 sssss1569
It a 4 pin I can see in the pic
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
The Following User Says Thank You to 1loudyukonxl For This Useful Post:
Kevin.Ross (11-22-2011)
Old 11-22-2011, 08:49 PM
got160s?'s Avatar
0/11 ssss13630
Originally Posted by gibsonm21 View Post
How is this?
The rating on this alternator is what it will do on a stock charging system.
With higher voltage it will yield higher output.
Sub Amp: 3 DC 9k's
Old 11-22-2011, 09:10 PM
gibsonm21's Avatar
0/11 ssssss392
If it will do 400amps at 16 volts, it will do 400amps at 14.
"WHEN you're thinking of replacing a blown fuse with a higher rated fuse ask yourself if you know more than the engineer who designed the equipment."
The Following User Says Thank You to gibsonm21 For This Useful Post:
obrien202 (11-22-2011)
Old 11-22-2011, 10:22 PM
got160s?'s Avatar
0/11 ssss13630
Incorrect. Higher voltage = higher amperage
Sub Amp: 3 DC 9k's
FS: Mike Singer 250amp Ford 6G Alternator jonny101abc Wiring, Electrical & Other Installation Equipment 6 05-28-2011 11:53 PM
Lifetime Warranty muriloalvares Team SounDigital 24 10-07-2010 07:21 PM
[SOLD]: U.S.amps Md3d amp 2000 by 1 at 1ohm $330 shipped jrplayer36 Mono Amplifiers 7 07-11-2010 06:01 PM
C&D batterie's new with 3year warranty cheap Slammintriple6 Bargain Bin 17 04-21-2010 04:32 PM
LIFETIME WARRANTY for Competitors and Show cars muriloalvares General Car Audio Discussion & Questions 8 11-04-2009 04:45 AM
