FS: BNIB 270a Mechman 6g Ford - Car Audio Classifieds!
Old 11-26-2011, 05:46 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
Default FS: BNIB 270a Mechman 6g Ford
1. Product: 270a mechman ford 6g alt setup for ext regulator
2. Specs: 270a/ 165a @ idle
will fit a pretty wide array of vehicles, post or pm me what you have and i'll let you know if it fits.
3. Description/Condition: BNIB
4. Price: : 350 + ship
new price 325 shipped 400 shipped with external regulator
no trades
Old 01-04-2012, 10:17 AM
Veteran Member
0/11 sssss3026
Originally Posted by MECHMAN View Post
This unit is normally $499 for the unit to run with an external, he's saving you $150!
Thanks man!
Originally Posted by bigdhenderson View Post
whats it mean "setup for external regulator" , you mean the PCM controlled?
external regulator is a seperate box that wires into the alt. It has a dial to set your voltage, so you can set it anywhere from 13.0 to 20+ volts, if you wanted to.
you have the regulator for it too? Or where can I get one
i have one but i was planning on keeping it as i will be using it with my next setup. mechman, as well as most other large alt companies, sell them.
if you have trouble finding one and want the alt i'll sell you mine though. It is bnib from mechman as well.
So using this as a primary alt will allow you to bypass the PCM controlled headache huh? Or I could find a way to mount this as a 2nd and control it with the external reg and the pcm controls the primary alt.
Sorry for the q's, wish Mechman would chime in with some info.
its all good man.
you could do either or. Although i wouldn't run a 2nd alt ext reg and stock pcm regulated unit on a common electrical.
as far as i know most alternators can be converted to ext regulated and the external reg units can run 2-3 alts most of the time.
Originally Posted by pinkbunnysofdoom View Post
do you know if this will fit in a 2003 ford explorer?
pretty sure it will only fit a v8
the v6 uses a t mount like this i bleive
You can run this in place of the PCM controlled unit but you will illuminate your battery charge light, may set your check engine light and may experience other issues with the PCM when it doesn't see an alternator connected.
this.
my 99 explorer 4.0 and my 02 expedition 5.4 neither set a light off, jusst for reference.
^^ perfect addition to this alt!
ext regulators are universal btw.
Originally Posted by CortezDTV View Post
Call or txt 831 5666061
Will this fit a 99 grand marquis,or crown vic
4.6?
just sent you a message
Originally Posted by art1618 View Post
ford 2010 4.6l? will it work as a drop in? its for a buddy so the less mods the better.
it will not work as a drop in unless you have an alternator shop convert it to the correct regulator configuration for your vehicle.
i have no clue about that fittiment, the tool i use only goes up to 09 and it doesn't even say for that. i can get up with mechman if your interested.
Originally Posted by stang65 View Post
I have a 2002 f150 5.4l v8. Will it work?
if it looks like this the picture below then yes.
i know it will fit my 2002 5.4 expedition, so i would imagine it would, just double check it looks like that for me.
Originally Posted by ninos View Post
so will this fit a ford focus 2.3l
i believe your car uses this case, if so then it will not fit.
Originally Posted by MERQUE View Post
what external regulator does this come with?
the only one mechman sells.
god this is exactally what i need. but no cash
price drop
Old 01-04-2012, 04:24 PM
MECHMAN's Avatar
0/11 sssss1142
This unit will physically fit SOHC, Naturally Aspirated 4.6/5.4/6.8 Ford, Lincoln and Mercury applications with the 3g, 6g or Mitsubishi FULL SIZE units.
PCM controlled vehicles will experience a battery light and possibly a check engine light. I only experienced the battery light when running my PCM controlled car on an external regulator.
I can convert this back to an internally regulated model and provide connections for 3g and 6g applications. 3g must be non-PCM controlled, 6g or Mitsu can be internal or PCM regulated.
Serious shoppers can email me and I can tell you what we can do and what it will cost.
Old 01-05-2012, 08:49 AM
Veteran Member
0/11 sssss3026
thanks!
also thank you sonic for the consolidation!
Old 01-08-2012, 05:42 PM
Veteran Member
0/11 sssss3026
bump!
Old 01-12-2012, 09:17 AM
Veteran Member
0/11 sssss3026
bumpskiez
Old 01-16-2012, 06:45 PM
Veteran Member
0/11 sssss3026
if anyone is interested in getting this converted to internal regulated feel free to let me know and i'll see what i can do about having it done.
Old 01-22-2012, 01:19 PM
Veteran Member
0/11 sssss3026
i'll probably keep this up until i get my taxes back.. if it doesn't sell by then i'll just put it on..
Old 01-25-2012, 08:42 PM
Veteran Member
0/11 sssss3026
final bump...
Old 01-29-2012, 05:52 PM
0/11 ssssss510
will this fit a 2001 jeep
2 15 inch custom built subs power by shok 5k
fosgate T1 mids and highs powered by p400.4
deka 8a31, 2 xp 2000s shok 1/0 (Team Shok)
300a singer alt
Ford 5.4L & 4.6L Mechman 270a alternator heckvr4 Wiring, Electrical & Other Installation Equipment 10 11-09-2011 07:23 PM
Ford 5.4L & 4.6L Mechman 270a alternator $225 shipped iamsonic Wiring, Electrical & Other Installation Equipment 7 09-09-2011 12:25 PM
mechman 270a GM 3.4/3.8l kodak314 Wiring, Electrical & Other Installation Equipment 17 07-05-2011 05:21 AM
F/S - BNIB 270A Mechman GM Alternator SundownAudioNY Wiring, Electrical & Other Installation Equipment 29 07-14-2010 10:12 PM
