200 amp and 250 A large case GM truck SUV alternators - Car Audio Classifieds!
Old 12-23-2011, 06:13 PM
0/11 sssssss90
Default 200 amp and 250 A large case GM truck SUV alternators
All of these units are the same standard GM large case housing with oval 4 pin plug. They will fit 1996 - 2004 GM trucks and SUV's with the following engines: 4.3, 4.8, 5.0, 5.3, 5.7, 6.0, 6.6 diesel and 8.1L
(4) 200 amp (125 idle) high output large case GM AD244 alternators
(1) 250 amp (150 idle) high output large case GM AD244 alternator
Amperage's are listed for each. 49 mm diameter 6 groove billet steel pulleys, 6mm output studs. 200 amp units have high-flow DR44 rectifiers that have been proven to be very durable.
These units fit 1996 through 2004 GM trucks and SUV's with the following engines: 4.3L , 4.8L , 5.0L , 5.3L , 5.7L , 6.0L , 6.6L Diesel, 8.1L
These units have a standard oval shaped 4 pin plug. We WILL NOT recase, rebuild, re-wire or otherwise modify them to fit you Ford, Volvo, lawnmower, etc... They fit what they fit, we are just trying to get rid of them quick and cheap.
These units are effectively brand new. They have never been installed on a vehicle, they have merely been used to test out some new rectifiers and stators that we have been checking out. Each unit probably has 10 dyno pulls on it and that's it. Each unit comes with a 90 warranty on a return for repair basis.
PLEASE E-MAIL ME BECAUSE I DON'T GET ON THE FORUMS MUCH. USE COMPLETE SENTENCES THAT DESCRIBE EXACTLY WHAT YOU ARE INQUIRING ABOUT, BECAUSE I HAVE A LOT OF DIFFERENT ALTERNATORS FOR SALE. AMBIGUOUS, UN-PUNCTUATED, AND/OR IMPOSSIBLE TO UNDERSTAND TEXT SPEAK INQUIRIES WILL NOT BE RESPONDED TO.
[email protected]
Thank you in advance for helping me to maintain my sanity.
250 amp unit = $299
200 amp units = $249 each
Shipping is NOT included in the price. Price is FIRM, no trades. I can accept visa mastercard or paypal at the office.
shipping from:
2849 John Deere Dr
Knoxville TN 37917
Old 12-24-2011, 12:09 PM
0/11 sssssss90
bump.
Old 12-25-2011, 12:58 PM
0/11 sssssss90
Yes, these units can be used as a universal or secondary alternator if you wish. We can supply you with the single-wire pigtail for $5 additional, so they are very easy to wire up as a stand alone alternator.
The 4 200 amp units would be a great bomb-proof quad alt setup for a really great price...
Old 12-26-2011, 11:14 AM
0/11 sssssss90
Still available. Up.
Old 12-26-2011, 05:46 PM
0/11 sssssss90
260 amp unit is SOLD.
250 amp unit and (4) 200 amp large case units still available
Old 12-29-2011, 12:24 AM
twistafleXXXin_540i's Avatar
Audiogasms * Hz So Good!
0/11 sssssss66
Question fitment ??
I have a 94 burban w/ 5.7 will either of these work??
2 RE Audio MX15.D1*DC Audio 3.5K * DC Audio 175.4
JVC KW-AVX738 DOUBLE DIN 7" DVD
ZEN Hypnotic 6.5 components * Cadence 4x6
3 Kinetik HC2000 2 runs 1/0 Knu Fleks
TEAM DC AUDIO 2012
Old 12-31-2011, 09:52 AM
0/11 sssssss90
Yes. They will fit but will need a plug adapter. I have the necessary harness adapter for $15
Old 12-31-2011, 10:53 AM
Ali888's Avatar
0/11 ssssss674
Default @matt
pls check ur pm
Digital Designs.....GrounD PoundeR!!!
Old 01-01-2012, 10:45 AM
0/11 sssssss90
PM and email both responded to.
Old 01-03-2012, 05:57 PM
0/11 sssssss90
Bump, still available. Can't believe nobody is jumping on brand new 200 amp units for $249. ...
250 amp iraggi gm large case Xtremelegend Wiring, Electrical & Other Installation Equipment 3 05-21-2011 10:43 PM
250 amp Mechman GM large case alt. 240shipped tahoefixssd Wiring, Electrical & Other Installation Equipment 12 12-30-2010 08:54 PM
Two Large Case GM Alternators [Getting out of CA sale] thumper21 Wiring, Electrical & Other Installation Equipment 25 07-22-2010 07:17 AM
1999 Dodge Truck / SUV WITH 5.2 & 5.9L jonesy Miscellaneous Stuff For Sale 4 10-09-2009 02:54 AM
250 amp and 300 amp GM large case units MECHMAN Wiring, Electrical & Other Installation Equipment 1 07-08-2009 12:38 PM
