300 amp Ford alternator built by H.O. - Car Audio Classifieds!
Old 01-23-2012, 10:57 PM
RustyWCA's Avatar
DC Ring Leader
0/11 sssss1292
Default 300 amp Ford alternator built by H.O.
H.O. alternator for a Ford
300 amp 18 volt adjustable fits 4.6l and 5.4l ford SOHC v8, and also ford v10
used, came off the DC Audio astro van
250 + 20 shipping in the US
(855)SPL-DBZZ
(855)775-3299
GET CONNECTED
Old 01-24-2012, 02:33 AM
Loyal Member
0/11 sssss2152
Feedback Score: 35 reviews
Is this adjustable for 12v use? Looks externally regulated
I'm just gonna ask my landlord to hold the car up while I take the tires off. I mean, she's old and all but should be okay.
Old 01-24-2012, 07:34 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Yes. With the external regulator you can set the charging voltage between 13-20v.
Old 01-24-2012, 07:53 PM
stang65's Avatar
0/11 ssssss540
would this be ok to run with 1 AQ3500.1? or would this be wayy to much overkill for it?
2005 f250 powerstroke, bulletproof 6.0, MTW stage 2 turbo, air dog fp150 fuel system,k&n intake, mbrp 4" exhuast, auto meter pillar gauges, sct tuner w/ custom tunes, 7" lift w/ 20" rockstars on 35s
System:
Kicker solo x 12 in 5cubes @ 32Hz
Audiopipe [email protected]
F/S new ford ohio gen 300+ amp alternator AbsoluteAudio Wiring, Electrical & Other Installation Equipment 12 07-13-2012 12:33 AM
Ford 5.4L & 4.6L Mechman 270a alternator heckvr4 Wiring, Electrical & Other Installation Equipment 10 11-09-2011 08:23 PM
300 amp Ford 3G series alternator The Doctor Wiring, Electrical & Other Installation Equipment 12 07-15-2010 09:19 PM
Ford 130 Amp alternator Josh Wahlie Wiring, Electrical & Other Installation Equipment 1 06-10-2010 02:43 PM
