woofertester 2 - Car Audio Classifieds!
Old 01-29-2012, 08:51 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
Default woofertester 2
1. Product: woofertester 2
theile small parameter tester
includes all pieces that are included in a brand new unit including calibration resistor
Thiele-Small Driver Measurement
With the Woofer Tester 2, measuring a driver's Thiele-Small parameters is easy. Q/FS, Vas and motor parameters are measured with a single click of a button. Vas can be measured with the Delta Mass, Delta Box or Efficiency method. The tester's sophisticated model takes phase-plug area into account as well.
For Impedance & Phase testing, a fast, under 1 second, test mode is available. This is useful for crossover design or a quick, production line test of a driver. Various Impulse, MLS, Noise, Sine, Chirp test signals are available in fast mode. Note that this mode is not as precise and is not recommended in a final speaker design. Additionally, the Woofer Tester 2 allows you to see the Cms trend versus drive level.
3. Description/Condition: brand new never used opened for pictures only
4. Price: : 140 shipped they are 160 new from woofertester.comhttp://www.woofertester.com/wt2product.htm
Old 02-02-2012, 07:35 PM
Veteran Member
0/11 sssss3830
bump for actually making good boxes based on parameters of real woofers not published specs
The Following User Says Thank You to psychoacoustics For This Useful Post:
Novicaine (02-19-2012)
Old 02-03-2012, 10:42 AM
mcmuffin's Avatar
0/11 sssss3380
how much of a ***** is this thing to use
*** NEW BUILD COMING SOON ***
its a secret for now
Old 02-03-2012, 11:09 AM
OldSchoolRF's Avatar
0/11 ssssss741
$125 shipped? Have Paypal ready so lmk. Thanks!
Old 02-03-2012, 12:13 PM
Veteran Member
0/11 sssss3830
this is super easy and highly accurate it is not however the wt3 from parts express that is a knock off
no thanks its brand new ill hold on to it i have never used it i have the woofertester pro so this is contained inside that unit
Old 02-03-2012, 12:45 PM
0/11 ssssss741
Alright thanks anyway. Lmk if you change your mind.
Old 02-05-2012, 10:15 PM
Veteran Member
0/11 sssss3830
superbowl bump
Old 02-08-2012, 02:55 PM
0/11 ssssss165
will it work on windows 7?
Old 02-11-2012, 07:40 PM
Veteran Member
0/11 sssss3830
yep 100% compatible on that i use mine on win7 and xp
Old 02-16-2012, 09:45 PM
Veteran Member
0/11 sssss3830
who simulates/designs/builds boxes and dont have one of these?
