ARM DSO Nano O-scope - Car Audio Classifieds!
Old 02-03-2012, 10:27 AM
0/11 ssssss728
Feedback Score: 42 reviews
Default ARM DSO Nano O-scope
1. Product: ARM DSO Nano Oscilloscope
Display:2.8" Color TFT LCD
Display Resolution:320240
Display Color:65K
Analog bandwidth:0 - 1MHz
Max sample rate:1Msps 12Bits
Sample memory depth:4096 Point
Horizontal sensitivity:1uS/Div~10S/Div (1-2-5 Step)
Horizontal position:adjustable with indicator
Vertical sensitivity:10mV/Div~10V/Div (with 1 probe)
0.5V/Div~100V/Div (with 10 probe)
Vertical position :adjustable with indicator
Input impedance:>500Kω
Max input voltage:80Vpp (by 1 probe)
CouplingC
Trig modes:Auto, Norma, Single, None and Scan
Functionalities:Automatic measurement: frequency, cycle, duty, Vpp, Vram, Vavg and DC voltage
      Precise vertical measurement with markers
      Precise horizontal measurement with markers
      Rising/falling edge trigger
      Trig level adjustable with indicator
      Trig sensitivity adjustable with indicator
      Hold/run feature
Test signal:Built-in 10Hz~1MHz (1-2-5 Step)
Waveform storage:SD card
PC connection via USB:as SD card reader
Upgrade:by boot loader via USB
Power supply:3.7V Chargeable Lithium battery / USB
Dimension (w/o probe):105mm X 53mm X 8mm
3. Description/Condition: Good condition, 100% functional. This was my first and only o-scope experience so I don't know how it compares to others. Seems to work good and other people on the forum seem to like it.
4. Price: :$50 shipped
Old 02-03-2012, 01:56 PM
0/11 sssss1801
Feedback Score: 17 reviews
Is hard to use
Old 02-03-2012, 02:07 PM
0/11 ssssss728
Took me a little bit to figure it out but there is some videos on youtube you can check out.
Old 02-03-2012, 03:37 PM
infaredsinsor's Avatar
0/11 ssssss769
Very slick device. Free bump, GLWS
Subs, amps, and power
AFEX Fire Suppression Systems Quality Engineer
itrader info available on profile
Old 02-03-2012, 03:46 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
Is it accurate though? Doesn't Taylorfade have one of these?
Old 02-03-2012, 03:50 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Yes, Taylorfade has one. They are intended for very lite use and lack some features that make it truly useful. These have a very slow sample rate of 1Ms/s and an input voltage of 80Vpp.
If you want something to tinker with and don't mind being somewhat limited then this works.
The Following User Says Thank You to audioarsonal For This Useful Post:
oslouie (02-03-2012)
Old 02-03-2012, 05:31 PM
0/11 ssssss728
Sale pending
who makes good mids and highs that dont cost an arm and a leg like focal and hertz? SiPPiNOnSuMBuD Sound Quality Area 21 01-04-2012 11:00 PM
DSO NANO question HELP Ajax_6154 General Car Audio Discussion & Questions 2 10-20-2011 09:18 PM
15" split arm 4 spoke Basket 6 x 5" pattern Audio_phill Speaker Accessories & Parts 5 05-08-2011 02:45 PM
Project Arm rest Lord Baccus Build Logs 16 05-01-2010 01:47 PM
[SOLD] Energy Suspension Polyurethane Front Control Arm Bushing Kit for Tacoma - BNIB toolguy420 Miscellaneous Stuff For Sale 11 12-22-2009 01:01 PM
