FS: Fluke 99B Scopemeter Series II Handheld Oscilloscope 100 MHz - Car Audio Classifieds!
Old 02-05-2012, 04:54 PM
Masterofallbass's Avatar
Team Minnesota's Loudest
0/11 sssss1973
Default FS: Fluke 99B Scopemeter Series II Handheld Oscilloscope 100 MHz
Fluke 99B Scopemeter Series II Handheld Oscilloscope 100 MHz, Dual Channel, 5 GS / s
Dual-input oscilloscope and high bandwidth true RMS Meter in one instrument
Scope Mode
100 MHz dual-trace DSO
Continuous Autoset to select the proper time base,
input range and trigger level
MIN/MAX Envelope Mode record the waveform
excursions with a gray scale envelope on both inputs
40 ns Glitch Detect for sweep speeds 1ms/div or
slower on input A
Analog-like gray-scale display
Waveform Average smoothing up to 256 waveforms, 10
samples in Roll Mode
Vertical resolution 8 bit (256 levels), 1mV/div
Record length 256 or 512 samples (10 or 20 divisions)
Delay trigger by 1 to 1023 events after external trigger
Cursor measurements up to 5 displayed
simultaneously
Waveform mathematics, add, subtract, multiply, invert,
filter, integrate
Zoom magnifies waveform around the 4th division at
the next sweep
Memory to save setups, waveforms and screen
Direct connect to a PC or printer
Meter Mode
Displays up to 4 readings and a full screen width scope
waveform of input A
TrendPlot with date and time stamp to record mins.
Hrs. or days of measurements
DCV, ACV true RMS, Ohm, diode test, frequency 1 Hz
to 5 MHz, RPM, duty cycle, pulse width, dBV, dBm, dBW
or audio/RF watts
Data smooth, fast update, change alert, TouchHold,
relative, % change and % scale
Signal Generator
Sinewave 1V at 976 Hz with less than 3% distortion
Squarewave 5Vpp at 488Hz, 976Hz or 1.95kHz
General Specification
Display: 84x84mm(4.7" diagonal), 240x240 pixels with
back light
Power: 4.8V NiCad battery, 4 hours operating time
Memory back-up battery CR2032 for 3 years
Weight: 4.0lb with holster
MHz Bandwidth
100
Number of Channels
2
Max. Repetitive Sample Rate
5GS/s
Scope Record
30k
Continuous Autoset
Yes
Measure Menu Automatic Setups
Yes
Multimeter Display with Full Width Waveform
Yes
Time/Division
5ns-60s
Vertical Resolution & Max. Sensitivity
8 bits, 1mV/div
Video Triggering & Pre/Post Trigger
Yes
Envelope & Variable Persistance Display
Yes
Oscilloscope Cursor Reading
Yes
Glitch Capture-40ns
Yes
Automatic Setup Measurements
40
Screen Memory
10
Waveform Memory
20
Set-up Memory
40
Waveform Math & Filter
Yes
Signal Generator Output - 4 Fixed Frequencies
Yes
Component Tester Output - Volts & Current
Yes
Optically Isolated RS-232 Interface for Printer & PC
Yes
PC Software(Windows) & Cable
Optional
CRT 4.7" diag./Backlit Display
Yes
DC Volt
300mV - 300V
AC Volt True RMS
300mV - 250V
Resistance
0 - 30MW
Frequency
1Hz - 5MHz
dBm
16 settings
dBW/Audio Watts
1,2,4,8,50W
TrendPlot with Time & Date Stamp
Yes
100% Fully working. This is NOT refubished. Shows light use. Screen is NOT scratched and still has factory film cover on the screen. Comes with everything shown in pictures. Holds batteries but theres no batteries in it.
Refurbished prices on these are over $1000 and over $2000 new
Asking $450 or BO
USD to
2010 MidWest Spl: Xtreme 1 Champion - Kaos Champion - No Wall 3rd Place
2011 MidWest Spl: Xtreme 3 3rd Place - Advanced 2 6th Place
2012 MidWest Spl: Xtreme 3 3rd Place - Advanced 2 5th Place
2013 MidWest Spl: Xtreme 4 3rd Place - Advanced 3 6th Place
2014 MidWest Spl: Xtreme 4 Champion - Kaos 4 2nd Place - Advanced 3 3rd Place
2015 USACI: Street Beat 4 World Record Holder
Old 02-07-2012, 12:52 AM
0/11 sssss1973
Bump!
Old 02-07-2012, 10:59 AM
0/11 ssssss391
That's a nice O-scope.. too bad it's out of my budget. :/ GLWS!
Old 02-07-2012, 02:48 PM
0/11 sssss1973
make an offer
Old 02-07-2012, 07:33 PM
0/11 sssss1801
Feedback Score: 17 reviews
you wouldnt happen to know a cheap place to get these fixed would u
Old 02-07-2012, 07:36 PM
0/11 sssss1973
i would have no idea
Old 02-09-2012, 03:55 PM
0/11 sssss1973
Bump, Price drop
Old 02-18-2012, 12:06 AM
0/11 sssss1973
Bump!
Wilson Electronics cell phone amplifier 811201 Dual Band 800/1900 MHz ampjunkielikeme Miscellaneous Stuff For Sale 0 06-13-2011 12:35 PM
oscilloscope o-scope thel.t.d.supply General Car Audio Discussion & Questions 0 03-27-2011 08:24 PM
i want a Oscilloscope.... midnite toka General Car Audio Discussion & Questions 20 07-03-2010 09:54 AM
oscilloscope... midnite toka General Car Audio Discussion & Questions 0 05-05-2010 11:48 PM
[SOLD] fluke 87III true rms DMM, fluke 322 clamp meter lincolntc690 Wiring, Electrical & Other Installation Equipment 10 06-18-2009 07:29 PM
