25 farad carbon cap / Rockford Fosgate - Car Audio Classifieds!
Old 02-16-2012, 07:09 PM
Wheres The Butta's Avatar
0/11 sssss6101
Feedback Score: 21 reviews
Default 25 farad carbon cap / Rockford Fosgate
1. Product: Rockford Fosgate 25 farad carbon capacitor. This is not a replacement for a good electrical system, but is a good supplement to one since it discharges much faster than a battery bank. It will help with dynamic impact.
2. Specs: Two 1/0 inputs - one for positive and one for negative, and then 6 outputs, three 4 gauge positive and three 4 gauge negative.
Rockford Fosgate CPCC25 Specifications
Price & Contact: $339.95; www.rockfordfosgate.com
Rated Capacitance: 25 Farads
Capacitance Tolerance: -10%/30%
Rated Voltage: 16 volts
Surge Voltage: 17 volts
Rated Current: 40 amps
Maximum Current: 250 amps @ 12.6 volts
Maximum Stored Energy: 3200 Joules (0.9 Wh)
Maximum Internal Resistance (ESR): DC (50A): less than 14milli-ohms; AC(50 Hz): less than 14milli-ohms
Operating Temperature Range*: -40 to 140 degrees F (-40 to 60 degrees C)
Storage Temperature: -40 to 158 degrees F
(-40 to 70 degrees C)
Input /Output Connection: (1) 2 AWG, (3) 4 AWG
Dimensions: 3.15 inches x 10 inches x 7.56 inches (80 mm x 254 mm x 192 mm)
3. Description/Condition: has a couple scuffs, but works fine. Has all set screws.
4. Price: : $50 + shipping (it's not very heavy, shipping should be cheap)
____________________________________
IASCA Pro AM and MECA Modex -->
Old 02-16-2012, 07:26 PM
OldSchoolRF's Avatar
0/11 ssssss741
Edit...
Old 02-17-2012, 10:13 PM
Nik592's Avatar
0/11 sssss2000
this has a pretty accurate voltmeter display?
"Insert witty signature here"
Old 02-17-2012, 11:14 PM
0/11 sssss1406
Do you have any other pics?
Old 02-18-2012, 09:21 AM
Post whore with a cause
0/11 sssss1937
Feedback Score: 22 reviews
Is this only for 16v systems? :-s
Well I got something for you from the late great Colonel Sanders who said "I'm too drunk to taste this chicken"
Old 02-18-2012, 09:27 AM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Feedback Score: 23 reviews
12v I believe. Seeing that 16v systems charge 18v+
these are badass caps
Team XS Power
Team Heavy Hertz
Build-
youtube-
Old 02-18-2012, 10:03 AM
0/11 ssssss741
I am interested as well but is this the one that only has one 2 gauge in and three 4 gauge out? Thanks
Old 02-20-2012, 06:47 PM
0/11 ssssss911
look at your facebook i asked about it there this is all
91 honda accord lx:
Old 02-20-2012, 07:11 PM
0/11 sssss6101
It has a red voltage display, but I don't have a picture of it hooked up. I assume the voltage display is accurate since RF makes good quality gear.
It has two 1/0 gauge inputs - one for power and one for ground - and 6 4 gauge outputs, three for power and three for ground.
Old 02-24-2012, 07:11 PM
lilteddyp's Avatar
0/11 ssssss403
50 shipped to 48842? Or if it's cheaper a business address in 48917?
2001 Bravada (2wd) Pewter|JVC KW-AV60BT|Alpine Interiors|2 PSI/BTL 18's @ 32Hz|2 Rockford Fosgate T25001-bd's @ 4-ohm each|Rockford Fosgate T1000-4 on Mids|Rockford Fosgate T400-4|RF 3Sixty.2|Yellow Top up front 2 9a31s in back|LOTS of AT 1/0|Python 991|350a Singer Alt
2 Rockford Fosgate 1 Farad Capacitors michigancapri92 Wiring, Electrical & Other Installation Equipment 1 07-10-2011 12:08 PM
[SOLD] Rockford Fosgate 1 Farad Digital Cap.. korn4life Wiring, Electrical & Other Installation Equipment 10 08-27-2010 10:01 AM
[SOLD] $15 shipped fosgate digital cap 1 farad sound_around Wiring, Electrical & Other Installation Equipment 11 08-04-2009 06:02 PM
FS used rockford fosgate 1 farad cap sound_around Wiring, Electrical & Other Installation Equipment 4 05-02-2009 05:43 PM
[SOLD] Fs: Rockford fosgate 1 farad cap flores210 Wiring, Electrical & Other Installation Equipment 4 11-02-2008 02:35 PM
