Kinetik Hc800 for 99technine - Car Audio Classifieds!
Old 03-31-2012, 11:00 PM
rdooski3's Avatar
0/11 ssssss625
Default Kinetik Hc800 for 99technine
Thread is only for 99technine
Kinetik Hc800
Kinetik High Current AGM Power Cell
This Kinetik 12-Volt Car Audio Power Cell features a sealed absorbed glass mat (AGM) design and is perfect for 800-watt car audio sound systems. The HC800 can be used as a replacement for your vehicles standard battery or as an additional battery to provide the extra power needed for a high performance aftermarket system. It's leak-proof design and no external vents allow this power cell to fit in most factory battery locations with no hazardous leaks.
Kinetik's KHC800 Power Cell puts out 950 cranking amps with a 36 amp hour rating. This battery will resist extreme heat conditions and vibrations and is 100% sealed in a reinforced ABS plastic case. Kinetik has equipped this power cell with more plates for stronger energy density and a high voltage underload. You will love the way Kinetik batteries get your system powered up and ready to go!
Battery Features
12V High Current Car Audio Power Cell
Sealed absorbed glass mat (AGM) design
Can be used as a replacement for your vehicles standard battery
Can also be used as an additional battery to power your high-performance sound system
Perfect for 800W car audio stereo systems
Stores energy so you don't need a capacitor for your system
Leak-Proof, non-hazardous design
No external vents allow this battery to be mounted anywhere with no leaks
Fits in almost any factory battery location
Ultra low ESR
More plates for stronger energy density
Higher voltage under load
100% Sealed and maintenance free
Tightly packed cells
Resists extreme heat & vibrations for ultimate performance
Authorized Internet Dealer
1-year Manufacturer's warranty
Battery Specifications
Cranking Amps: 950
Amp Hours: 36
Weight: 26 lbs.
Dimensions: 5D x 7-5/8W x 6H
Few months old. Great condition.
$85 Shipped
FS: Kinetik hc800 ChevyBoy95 Wiring, Electrical & Other Installation Equipment 21 05-09-2012 05:32 AM
Kinetik hc800 premierdime Wiring, Electrical & Other Installation Equipment 19 04-04-2011 05:55 PM
Kinetik HC800 NickCJ7 Wiring, Electrical & Other Installation Equipment 15 03-10-2011 07:24 PM
Kinetik HC800 MmatsDude Wiring, Electrical & Other Installation Equipment 2 02-12-2009 06:01 AM
