Metal flared aeroports built custom - Car Audio Classifieds!
Old 04-11-2012, 12:44 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
Default Metal flared aeroports built custom
metal aeroports
made of:
galvanized steel
Stainless steel
and Aluminium
any size or length from 3-48" in diameter in 1" increments
any length you want from flare to flare with no tubing to 4' long its available if you wanted
want adjustable ones ?
Fully adjustable metal aeroports perfect for SPL testing and competition!
ill leave the 3" 4" 6" ones to the guys who make them from plastic and mass produce them they are much cheaper, unless you really want them id go with a psp port
the ports are made from the metal of your choice. they are paintable and very strong !
all seams are spot welded and can be sealed with either silicone or something of your choice either by you or me
all seams are made with a flange to be tight and smooth on the inside (airflow side of the port)
these will give you an increase over a traditional slot port and are not as permanent they can be adjusted !
they are not going to ring and have been tested to not ring it was a question in a few of the early prototypes if you are still concerned i can apply deadener to them just like your door or roof
the 3-5"
have an 1.5" radius flare and have a 1" flange for mounting and are 2.5" in length
so a 4" flare will measure 9" on the outer most edge 4+1.5+1.5+1+1
to figure length you will add 5" to your tube length
so if you wanted a 17" port from end to end you would do the following to yield a 12" tube
17-2.5-2.5=12" tube
the 6-10" flares are 3" tall with a 2" radius and a 1" flange the same math will apply as above
for a 7" port 18" long :
7+2+2+1+1=13" outer diameter
18-3-3=12" tube length
here is a port area cheat sheet to determine how big of one you need
just use these numbers in your box designs as port area of the size you need
4" 12.59 sq"
5" 19.62 sq"
6" 28.26 sq"
7" 38.46 sq"
8" 50.24 sq"
9" 63.58 sq"
10" 78.50 sq"
11" 94.98 sq"
12" 113.04sq"
these prices are for any length up to 24" of tubing and they will come in a 2 piece configuration ( one flare is attached to the tube and one loose flare )
shipping not included but i will fully insure them and ship them in a plywood reinforced box with them bolted down to ensure no damage comes to them
other options are available such as:
both flares loose
another length of tube to make longer than 22"
mounting holes drilled out
mounting screws
metal colored silicone sealant makes the seams virtually invisible
4" 50$
5" 60$
6" 75$
7" 90$
8" 100$
9" 125$
10" 140$
11" 160$
12" 180$
larger sizes are available but i really don't see them being to popular so if you want a larger one contact me
this is a 7" flare inside
this is a 7" flare outside
this is the inside shown with the flare to pipe transition being very smooth
this is how it looks from the outside
Last edited by psychoacoustics; 08-04-2012 at 07:46 PM. Reason: shipping info added
The Following 2 Users Say Thank You to psychoacoustics For This Useful Post:
crunkjuice1 (07-01-2012), EpicenterDesigns (04-30-2012)
Old 04-11-2012, 12:52 PM
Anton Miller's Avatar
DoucheMiller
0/11 sssss3720
very cool! might be talking with you soon!
1997 CHEVY CAVALIER - BUILT FOR EFFICIENCY!! YOUTUBE:
Old 04-11-2012, 12:57 PM
kmanian1's Avatar
mine>yours
0/11 sssss2130
so if I wanted a 15" outside diameter on the flare, I would be looking at a 9" tube. correct?
Old 04-11-2012, 01:02 PM
Veteran Member
0/11 sssss3830
yes that is correct
OD-flange-flange-radius-radius= tube size diameter
15- 1-1-2-2=9"
i can cut the flange to fit around another woofer if it helps just give me the center points and diameter and ill cut an arc off of the edge
Old 04-11-2012, 01:20 PM
groundpound4200's Avatar
Errday I'm Hustlin'
0/11 sssss1785
wow, you have all the cool toys there don't ya?
2007 Honda Pilot
Sundown SAZ 1500D V.3
2 Atomic APX 818 10"s
Taylor Lampart aka NewAgeKing
Old 04-11-2012, 01:47 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
Shipped prices? what gauge are these made out of?
Old 04-11-2012, 01:58 PM
Veteran Member
0/11 sssss3830
shipping was what i was planning on adding to the next post but people started replying
thickness is 20 awg
all shipping will be done in a box a few inches larger than the flare with them attached a a piece of plywood with a couple blocks so they cant move or be crushed
very similar to mounting a woofer but i will not screw into the flange and they will be insured for the nearest 100$ over the sale price
the 10" i shipped out a few weeks ago was 60$ for shipping insurance and boxing shipped to texas ( im in NY 14120 )
Old 04-11-2012, 02:42 PM
mhart's Avatar
0/11 ssssss721
Those look great, I might need one of these soon.
'00 civic si IASCA stock trunk/pickup 1 World Record Holder
'01 S-10
Team DC Audio Team XS Power Team ISB
Steve's Body Shop
Old 04-11-2012, 03:57 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
How would they not resonate? Wood does it, baskets do it etc. they look like nice quality just conerns me is all. Yes i read the green writing
The Following 2 Users Say Thank You to DonH For This Useful Post:
popwarhomie (04-26-2012), slowpoke (04-21-2012)
Old 04-11-2012, 04:14 PM
DonH's Avatar
0/11 sssss6645
Dbl post
Custom built 10 Helpicantswim Wanting to Buy (WTB) 2 04-05-2012 11:34 AM
Custom built pc kreapin Miscellaneous Stuff For Sale 6 12-24-2011 01:40 PM
F/S 6'' Flared Aeroports ''Bassman'' Wiring, Electrical & Other Installation Equipment 9 10-20-2011 12:36 AM
wtb 2 6inch flared aeroports hdman87 Wanting to Buy (WTB) 7 11-04-2010 08:01 PM
Built the best custom E8! resko1 (Sundown Audio) 10 01-30-2010 11:57 AM
