bnib Axxess ASWC - Car Audio Classifieds!
Old 06-02-2012, 06:08 PM
0/11 sssss1406
Default bnib Axxess ASWC
Same as title
Universal
Finally, a simple solution to retaining the steering wheel controls of a vehicle when installing an aftermarket stereo. Introducing the Axxess ASWC, from Metra Electronics. This universal steering wheel interface is brand new for the 2010 line of Metra Axxess components and is designed to make the installers life much simpler. Unlike other steering wheel interfaces, the ASWC requires no manual programming. After making all the proper connections, this interface will automatically program itself with the new stereo and the vehicle. No more tedious programming of each button. The ASWC has a LED status light that will flash according to the programming and inform you when the sync is done. Its simple. Just plug it in and you are ready to go! Now installations can be faster, easier, and simpler! If you still prefer to do the programing manually, Axxess has left that as an option. No matter what type of vehicle or aftermarket stereo you are planning on installing, the ASWC has you covered! It is fully compatible with Pioneer, Sony, Alpine, Kenwood, Eclipse, JVC, and more. As long as the stereo has a wired steering wheel remote connection, the ASWC will connect and interface with the vehicle. Plus, the Metra ASWC is able to be updated. This means that the interface will never be out dated. For the simplest way to retain the steering wheel control in your car, choose the Axxess ASWC!
40 shipped
axxess gmos-04 onstar and bose interface remi_357 Wiring, Electrical & Other Installation Equipment 2 08-28-2011 01:23 PM
~~ BNIB Pioneer GM-D8500M BNIB 1200 Watts Max. Two Available! ~~ amalmer71 Mono Amplifiers 13 11-21-2010 05:58 PM
axxess gmos-04 Plumbcrazy Wiring, Electrical & Other Installation Equipment 0 11-14-2010 07:37 PM
Metra Axxess ASWC Automatic steering wheel control! nismos14 Wiring, Electrical & Other Installation Equipment 19 05-19-2010 11:48 PM
[SOLD]FS: Axxess high power line output converter Ryan1126 Wiring, Electrical & Other Installation Equipment 10 03-06-2010 09:03 PM
