1 Audio Control 2XS - Car Audio Classifieds!
Old 06-04-2012, 02:02 AM
ridintwo6s's Avatar
0/11 sssss1791
Default 1 Audio Control 2XS
Audio Control 2xs
electronic crossover.
Concert Series 2-Way Crossover
Uses a steep 18 dB (90 Hz) per octave slope to separate your high and low frequencies
Built-In line driver improves signal from a weak receiver
One set of inputs and two sets of outputs (High-Pass and Low-Pass)
Built-In filter removes subsonics from your signal
Simple connection and setup
Balanced inputs reject noise caused by your vehicle's electrical system
Internal switching gives you other options for dealing with ground loops
Ground isolation selector allows you to change the power supply for different systems
Gold-Plated RCA jacks
Top-Mounted controls for easy adjustment
Frequency Response: 15-20,000 Hz
Signal-to-Noise Ratio: 115 dB
Maximum Output Level: 9.5 volts
Fuse rating: 1 amp
Color: Salmon Gray
Dimensions: 1-3/16"D x 4-11/16"W x 5-1/2"H
decent shape, used probably 7/10
$45 plus ship. will fit in flat rate.
will get better pictures if needed
Old 06-07-2012, 01:20 PM
ridintwo6s's Avatar
0/11 sssss1791
Bump ttt
Old 06-25-2012, 01:09 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
This still up?
Current Build:
#60sHereIcome
Old 06-25-2012, 01:25 AM
ridintwo6s's Avatar
0/11 sssss1791
sure is bud
Concert series Audio control 2xs nutxo Head Units, Processors & EQs 2 09-15-2011 05:05 PM
audio control matrix loondizie52 General Car Audio Discussion & Questions 3 07-25-2010 10:23 PM
WTT my xbox 360 w/ harddrive, 10 games, wireless control, wired control, and cooler djm4rshm2llow Car Audio Trader (WTT) 6 06-11-2010 02:28 PM
audio control JOSEPHKEMP Wanting to Buy (WTB) 1 08-16-2009 10:43 PM
Audio Control russhay78 Wanting to Buy (WTB) 0 04-25-2009 01:19 AM
