4th Order Bandpass for 2 12's in SoCal - Car Audio Classifieds!
Old 06-18-2012, 12:14 AM
0/11 ssssss295
Default 4th Order Bandpass for 2 12's in SoCal *Updated With New Pics*
4th order bandpass for 2 12's, 2:1 ratio with removable 4" aeroports for tuning changes
41" Wide
14.5" Tall
60* Slant with 25.5 top depth and 32.75 bottom depth
~2 cubes sealed
~4 cubes ported
tuned to 42 hertz right now
dowel bracing in ported section and custom brace in sealed section
removable rear pannel for sub access, can be replaced with plexi for showing off the subs
unfinished, and no holes drilled in the sides other than 2 1/4-20 terminals in left side
i built this for myself so no corners were cut, everything was glued very well and siliconed
Sounds great, very smooth response
100 picked up, just trying to cover cost of materials
Old 06-18-2012, 04:14 AM
spanyerd's Avatar
0/11 ssssss326
Are the walls glued and screwed to each other, or only glued? I only see screws for the braces but the pics aren't clear enough to tell for sure.
You gonna be in SD anytime soon?
Old 06-18-2012, 05:57 AM
briankeith1007's Avatar
0/11 ssssss374
Default What kind of subs this box was made for?
Hello,my name is Brian.what is this box made for?I love it.I have an Acura CL,and some Sundown 12's.Do you build to order and ship?
Old 06-18-2012, 06:02 AM
0/11 ssssss374
Default Love it.
Hello,my name is Brian.Do you build and ship?
Old 06-18-2012, 10:24 AM
0/11 ssssss295
All of the walls are glued with titebond wood glue then held together with brads to allow the glue to dry. The bracing uses glue and a screw in each end. If you are seriously interested I can probably meet you half way. I'm located by March Air Force Base off of the 215.
I built this box originally to have a nice smooth response because I was tired of how peaky my ported boxes were. I have since tunes it more for the lows, but I do have more center sections for the aero ports so you can adjust tuning frequency. I'm not going to ship it because it would be crazy expensive
Old 06-18-2012, 11:16 AM
0/11 ssssss295
Because the mods seem to be alittle trigger happy with deleting threads here are some new pics:
Old 06-20-2012, 11:16 AM
0/11 ssssss295
Any interest in a nice 4th order
I can travel to meet you half way if you are in SoCal
Old 06-25-2012, 02:13 PM
0/11 ssssss295
BUMP
90 picked up
I have more than that in materials...2 sheets mdf, dowels, aero ports, glue, nails, etc
Old 07-18-2012, 11:38 AM
0/11 ssssss295
Anyone? 50 bucks before I just throw it away
Old 07-18-2012, 11:41 AM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
i might snatch it up possibly, not sure what i would use it for though
8 12s-4th order bandpass SUBW123 Build Logs 11 03-30-2011 02:42 PM
4th order bandpass? wahvtec Enclosure Discussion & Design Construction Help 0 06-28-2010 04:53 PM
**FS: 4th Order Bandpass for 3 10s"** 528hz Wiring, Electrical & Other Installation Equipment 5 04-25-2010 07:38 PM
4th order bandpass users come in! murderedtahoe General Car Audio Discussion & Questions 19 04-18-2010 05:21 AM
4th order bandpass, two Type R 12's white4d96 Enclosure Discussion & Design Construction Help 0 11-07-2009 03:08 PM
