excessive amperage 300amp alternator - Car Audio Classifieds!
Old 03-13-2013, 04:12 PM
juancolchado's Avatar
CACO Savage
0/11 sssss2362
Feedback Score: 50 reviews
Default excessive amperage 300amp alternator
300 amps at 1800rpm
200amps at idle
Direct Fit Models Include :
CHRYSLER 300 2.7L 2005-2007
CHRYSLER 300 3.5L 2005-2007
CHRYSLER 300 5.7L 2005-2007
CHRYSLER 300 6.1L 2005-2007
DODGE CHARGER 2.7L 2006-2007
DODGE CHARGER 3.5L 2006-2007
DODGE CHARGER 5.7L 2006-2007
DODGE CHARGER 6.1L 2006-2007
DODGE MAGNUM 2.7L 2005-2007
DODGE MAGNUM 3.5L 2005-2007
DODGE MAGNUM 5.7L 2005-2007
DODGE MAGNUM 6.1L 2005-2007
Only used for about 2 months took out because my car idles at 500-600rpm and I thought the alternator was bad.
I sent it to tenney to check it out and he replaced the pulley and plug and stated everything was fine and was in working order.
I put it back in my car today and it did the same thing. I listen to my music at idle and i rather just keep my stock alty with MLA madual and batteries but if you listen to your music at full tilt driving down the roadthis is for you.
$300shipped or any good offer I will consider.
Yes trades are welcomed
Team SPLC
I Buy unique Subs, used or blown, motors also.
I buy XBL^2 subwoofers or motor.
Old 03-13-2013, 06:22 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Why not a smaller pulley so you get more amps at idle?
Old 03-13-2013, 07:09 PM
CACO Savage
0/11 sssss2362
It had a smaller pulley and the belt was slipping.
When tenney recived it he said it had a lot of belt dust
Team SPLC
Old 03-16-2013, 11:25 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
what's the measurement center to center on the bolt holes (the side with 2 holes, not one)
Old 03-16-2013, 11:52 PM
CACO Savage
0/11 sssss2362
Ill shoot you a text when I get off work.
Team SPLC
Old 03-20-2013, 06:02 PM
briankeith1007's Avatar
0/11 ssssss374
Default Wish this would fit an Acura CL 2003
Wish I could make this fit an 2003 Acura CL.
Old 03-20-2013, 08:22 PM
CACO Savage
0/11 sssss2362
OBO or trades... Need some a new headunit.
Team SPLC
Old 03-21-2013, 01:35 PM
0/11 sssss1898
You can buy a tuner and up your engines idle.
2002 suburban
Security System
Code alarm
Electrical
Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit
pioneer 880prs
Amps
Sax125.2 front stage 2 Saz-4500's [email protected] 1 ohm
Wiring
lots of 1/0 stinger, tsunami
Mids & Tweeters
Dd w6.5 mids and lanzar opti crossovers and tweets
Subs
4-18" nightshade v2's d2
System Details
Daily driver.
Old 03-23-2013, 05:07 PM
CACO Savage
0/11 sssss2362
up top meow
Team SPLC
Old 03-26-2013, 04:42 AM
CACO Savage
0/11 sssss2362
Offers?
Team SPLC
excessive amperage 200 amp alternator cs130 coleinalaska Wiring, Electrical & Other Installation Equipment 18 01-02-2013 03:04 AM
Fed ex lost my excessive amperage alternator and voltage regulator rhesketh General Car Audio Discussion & Questions 137 10-04-2012 09:02 PM
300amp excessive amperage alternator w/ external regulator-FORD CASE TeamXDMatt Wiring, Electrical & Other Installation Equipment 20 11-29-2011 05:06 PM
FS: 250A Excessive Amperage Alternator snb778 Wiring, Electrical & Other Installation Equipment 16 11-06-2009 12:05 AM
