270 Amp Singer Alternator for Jeep Grand Cherokee 98-02 4.0 liter - Car Audio Classifieds!
Old 04-16-2013, 10:41 PM
0/11 sssssss68
Default 270 Amp Singer Alternator for Jeep Grand Cherokee 98-02 4.0 liter
1. Singer 270 amp alt for 99-04 Jeep Grand Cherokee 4.0 liter :
2. adjustable voltage regulator.:
3. This 270 amp singer alternator is like new! all the moving parts were replaced and were never used when I got it back from Mike. The reason I sent it to him in the first place is because a couple wires going to the voltage regulator came loose and he fixed them and re routed the wires so that won't happen again. He also replaced all the moving parts and while it was there I had him paint it red too. Mike even said him self it's like a new alternator. This alt will be 1 year old on the 24th of May. I've Had no problems with it other than the wires issue around Christmas time. Sorry for the mistake! It fits 99-04 4.0 liter jeeps!!!
4. $300 obo!! Maybe even trade lol : :
image (2).jpg:
Old 04-16-2013, 11:15 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
That wont fit a 98 4.0 FYI. Nice alt tho.
Should fit 99-04 4.0s.
The Following User Says Thank You to 98GCLimited For This Useful Post:
LUKEiNATOR (04-16-2013)
Old 04-16-2013, 11:21 PM
0/11 sssssss68
ohhh shoot! thank you! I'll change that!
Old 04-17-2013, 03:04 PM
0/11 ssssss268
Feedback Score: 17 reviews
Why will it not fit a 98? is the wire connection diffrent
Old 04-17-2013, 06:26 PM
0/11 sssssss68
I think you would have to do some grinding on your motor mount for the alt. the alt doesn't have a plug. It has the regulator on top, the only wires that go to it are the positive battery wire and the ground.
Old 04-17-2013, 06:37 PM
0/11 sssss1921
Different mounting brackets all together and I think the connectors are different as well. Just wouldnt work at all.
Heres my Mechman I had on my 98. You can see the mounting brackets are totally different from the 99-04 4.0 alts.
Old 04-17-2013, 07:37 PM
0/11 ssssss268
Thanks for clearing that up, I took a 98 zj alt and with alittle grinding I installed it into mt 98 xj,the hook up on mine has the two nuts for that pcm connection and the power stud, I was looking for up grade on my stock alt.
Old 04-17-2013, 10:58 PM
0/11 sssssss68
Well I guess now we really know it doesn't fit! Thank you for sharing that with me.
Old 04-18-2013, 12:50 AM
0/11 ssssss536
I got the repair manual. From haynes and they are dirrent brackets
Old 04-21-2013, 10:58 AM
dat517boi's Avatar
0/11 ssssss834
what kind of trades in very interested in this
Vehicle: 2000 Jeep Grand Cherokee
Head Unit: JVC KD-R210
Sub: SA Nightshade V.1 18 x2
Sub Amp: Audioque AQ2200 x2
Battery: Optima Yellow Top, 9A31 x2
Alternator: 235 amp alt
can we start the bidding war for the sister and mom?? and can we get T/S parameters on both?
well unfortunately the t/s when they were new will be way diff now.... these drivers are used and beat on pretty hard in there day (not personal use but ive known all the owners and theres been alot)
Tags
alternators, mike singer, singer alt ad244
340 Amp Mechman alternator for jeep grand cherokee 6.1L or 5.7L jeep commander Mnorwood01 Wiring, Electrical & Other Installation Equipment 16 12-29-2012 11:09 PM
Jeep grand cherokee dual alternator kit and alternators, & ten kinetik 16 v batts Mnorwood01 Wiring, Electrical & Other Installation Equipment 8 12-28-2012 09:46 PM
