(2) Die Hard Platinum Marine Group 31 1150 CCA
(1) XS D3400
4 runs 2/0 for battery to amp
6 2/0 jumpers for connecting in bank
The cable is Coleman Royal and is some of the best stage cable made, this is much more flexible than your average welding cable.
Like new, all only a few months old. The black specs on batts are plastic dip over spray from another project in garage, will wipe off
475 picked up for all. Basically like buying the batteries and me giving you a d3400 and 2/0 for free. This setup will power a nice system. All was run in a bank with a intellicharger and a 380 amp alt Not wanting to seperate, if I do batteries will be 200 each.
The bars and 2/0 bars are 2in wide 1/2in thick, will get 4 short 4-6ft runs of the 2/0
Xs3400 resting voltage, been sitting a month.
Die Hard 1150 CCA resting voltage, same resting voltage on both, they were in a bank of 6
[/SIZE]
(1) XS D3400
[/SIZE]
