Knukonceptz 0g Wire, Inline fuse holders, Disto blocks, RCA's, Fuses etc. - Car Audio Classifieds!
Old 11-11-2013, 11:29 PM
0/11 sssssss25
Default Knukonceptz 0g Wire, Inline fuse holders, Disto blocks, RCA's, Fuses etc.
4 knukonceptz inline fuse holders
1 knukonceptz 150 Amp ANL fuse
3 knukonceptz 250 amp ANL fuses
1 knukonceptz disto block with fuses "power" (0g into 2 4g)
2 knukonceptz "krystal kable" RCA's forgot to check length (would say at least 2m)
1 RCA not sure who makes it
~5 foot run of knukonceptz 1/0 (black for ground)
~7 foot run of knukonceptz "KCA Kable" blue 1/0
~9 foot of knukonceptz "KCA Kable" blue 4g
1 knukonceptz battery terminal with 3, 1 foot runs of 1/0g
2 ~2 foot runs of knukonceptz 4g
Various runs of remote wire
1 Knukonceptz fuse holder that shows you the volts (cant find this on the website anymore)
FH / KNI Inline fuse holders provide fuse options ranging from 30A up to 450A. The FH series inline fuse holders utilize set screws to attach to the power wire while the KNI-11 is part of our KonFUSED series that terminates with a compression fitting at each end.
Silver Plated 150 Amp ANL Fuse
Silver Plated 250 Amp ANL Fuse
The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KNF-12 has one input port, which by changing the Kompression Fitting, can accept 4 Gauge or 1/0 Gauge Cable. The output side can be adjusted to accept 4 Gauge or 8 Gauge cables. Please see our reference chart link below to see what fittings are included with this model. Using the Mini-ANL Style Fuse, the KNF-12 can maintain loads up to 150A per circuit. Included with the KNF-12 are 6 Kompression Fittings to allow the end user to customize the block to fit their application. The fittings available with the KNF-12 are: one large 1/0 Gauge; one large 4 gauge; two small 4 gauge; two small 8 gauge. The Large fittings are used on the input side and the small fittings are used on the output side of the KNF-12 Also included, your choice of two (2) Mini-ANL fuses! The KNF-12 is finished in black chrome and includes the smoke acrylic cover
The Krystal Kable is one of the best cables on the market. It is the Fort Knox of cables, containing 4 different types of shield / noise rejection characteristics all in one RCA cable! Features Include:
  • Twisted Pair, Copper Foil wrapped Audio Signal
  • Sub-Layer PVC Jacket
  • Mylar Foil Shield
  • Tinned Copper Braid Covering 98% of the surface area
  • Gold Plated Metal Ends with Diagonal Kut Konnection
The Krystal RCA Cable uses Oxygen Free Copper for its audio path. Large 22 gauge twisted pair conductors deliver a clear and clean signal transfer from your head unit to your amplifiers. Termination of the Krystal RCA Interconnect is made complete with turbine cut, Gold Plated RCA connectors. Each end uses knurled metal rings to provide a sure grip for installation of the Krystal Kable. The 2 Meter (6.5') Cable is finished in a rugged translucent smoke color PVC.
KCA KABLE
Kolossus Copper Aluminum Kable (KCA Kable) has arrived! The KCA Kable uses the same ultra flex PVC found in the Kolossus Fleks Kable and the Copper Clad Aluminum (CCA) conductor from the KLMX Kable. Copper Clad Aluminum (CCA) is made up of 90% Aluminum and 10% Copper. CCA overall provides a cost effective solution to most audio systems. Assembled from stranded 34 gauge CCA, the KCA Kable is equal in size to the Kolossus Fleks Kable, but is designed for lighter current loads and not lightening your wallet. The KCA series 1/0 Black Cable offers improved flexibility over the 'KLMX' Series and a rugged PVC outer jacket that is impervious to grease and oil. The PVC outer jacket can with-stand the extreme temperatures (-40 to 105 C) and capable loads of 250A. Price is per foot.(*per meter in UK)
Knukonceptz Battery Terminal
KonFused Battery Terminals - User Konfigurable Battery Terminals! Each terminal accepts three large gauge fittings (1/0 / 2 / 4) Connect up to three 1/0 Gauge cables with the KBT-30's! Need three 4 Gauge outputs, no problem. How about a mix of both? Yep, it does that too. The wedge shape allows for three large gauge fittings while maintaining a compact design. Included standard with every terminal are three 1/0 gauge compression fittings and a single 4 gauge compression fitting. Additional fittings are available (sold separately). Each terminal also includes a protective, smoke tinted, acrylic cover with polarity indicator on both the terminal and cover. The KBT-30 fits top mount (post) batteries and is finished in Black Chrome.
Everything is either brand new/ never used or has been used in one install on my truck for ~6 months
$130 Shipped for all of it. (would prefer to sell all of it together)
Old 11-11-2013, 11:53 PM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
would you separate the 3 holders plus the 250a fuses?
Old 11-12-2013, 09:24 AM
speedkingrc's Avatar
0/11 ssssss219
how much for just rca's? shipped to 23435
Fresh Start with a JDM ITR
So looking for a new system
Old 11-12-2013, 03:07 PM
0/11 sssssss25
$65 shipped
$30 shipped
Old 11-13-2013, 09:46 PM
0/11 sssssss25
bump/
Old 11-14-2013, 10:20 PM
0/11 sssssss25
$100 shipped for all of it
Old 11-18-2013, 11:01 AM
bigfastmike's Avatar
0/11 sssssss42
Funds sent
Sent from my SCH-I605 using Tapatalk 2
Lots of 1/0 wire, fuses, fuse holders, dist blocks Bologna Wiring, Electrical & Other Installation Equipment 0 06-15-2013 03:24 PM
Wire, Fuse Holders, Rca's, Distro blocks 06GTMIKE Wiring, Electrical & Other Installation Equipment 8 01-11-2013 10:52 AM
4ga Wire, Fuses, Fuse Blocks, Fuse Holders, and USB Cables hari-bhari Wiring, Electrical & Other Installation Equipment 3 05-30-2012 05:14 PM
[SOLD] (2) Knukonceptz waterproof inline fuse holders- $25 shipped uglydimple12 Wiring, Electrical & Other Installation Equipment 2 08-23-2010 11:53 PM
[FOUND] 14 inline fuse holders - 300 amp fuses upzaw2000 Wanting to Buy (WTB) 10 07-27-2010 01:22 PM
