SPL LAB smart monitor - Car Audio Classifieds!
Old 01-26-2014, 02:58 PM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
Default SPL LAB smart monitor
spl smart monitor
Tech Specs
Measuring the direct current, voltage and power
Measuring the alternating current, voltage and power according to the True RMS algorithm
Measuring the impedance of the acoustic systems
Defining the harmonic distortion coefficient
Quality index assessments of home and industrial electric networks
Protection of electrical equipment of a car from breakage
Protection of car subwoofers and acoustics from overheating and breakage caused by uprating the allowed current / voltage or power of input signal
Matching levels (Gain) of different channels of the amplifiers against each other
Tuning the car audio and amplifiers by means of monitoring the harmonic distortion of the played back signal
The Smart Monitor car multimeter is a device for measuring such characteristics of electric circuits as power, voltage and current. There are two independent removable sensors used in the device: for direct and alternating current/voltage. Multimeter takes measurements of direct current and voltage (power) used by car amplifiers, as well as alternating current and voltage (power) delivered by amplifiers to subwoofer or other acoustic components. Thus the device is able to measure seven electric characteristics at the same time: alternating current up to 100 A, voltage up to 300 V and power up to 30 kVA; direct current up to 1200 А, voltage to 30 V, power up to 36 kVA and impedance. For measuring the alternating current/voltage and power the True RMS algorithm is used. The Smart Monitor also has a car electrical equipment protection feature that breaks the Remote controlling circuit when the measured values exceed the defined limits. Besides that the device has a signal Harmonic Distortion Measuring mode in the alternating current /voltage circuit. The Smart Monitor can carry out measurements and evaluate quality not only of a car electrical system but also of home and industrial electric networks with power up to 30 kW, voltage up to 300 V and current up to 100 ampere.
monitor is used but fully working . i got this as a trade and as much as i want to run it i am in the middle of a build so i need to sell to recoup funds . iirc correct mine has the 200a dc and 100 a ac sensor , here is a link with more info
Smart Monitor - protects and measure Volts, Amperes, Watts and signal clipping!
300 shipped in the u.s.
only trade towards a PIONEER AVH-X7500BT
Old 01-29-2014, 12:06 AM
caloriu's Avatar
0/11 sssss2863
bump for a trade towards a PIONEER AVH-X7500BT
Old 02-04-2014, 11:01 PM
caloriu's Avatar
0/11 sssss2863
to the top
Old 02-13-2014, 05:00 PM
caloriu's Avatar
0/11 sssss2863
to the top
Old 03-03-2014, 08:13 AM
caloriu's Avatar
0/11 sssss2863
bump...
Old 03-16-2014, 08:47 AM
caloriu's Avatar
0/11 sssss2863
re posted on a newer thread
FS: SPL Labs Smart Monitor Boomsday Wiring, Electrical & Other Installation Equipment 2 03-14-2013 01:05 PM
SPL labs smart monitor fosgatefeind Car Audio Trader (WTT) 24 01-12-2013 03:22 PM
