Stinger HPM3 20ft RCA cables nib, knu concepts distro block nib - Car Audio Classifieds!
Old 01-29-2014, 03:44 PM
Active Member
0/11 ssssss967
Default Stinger HPM3 20ft RCA cables nib, knu concepts distro block nib
1.stinger hpm3 20ft RCA cable new in box
2. Knu concepts distribution block new in box
3. Description/Condition:all new
4. Price:
1. $19 shipped each
2. $20 shipped
5. Pictures: pics in 2hrs I had this posted in wrong section
Old 01-29-2014, 04:47 PM
tv550's Avatar
0/11 sssss1658
Feedback Score: 37 reviews
If the stinger is a 4 channel Ill take it..
Old 01-29-2014, 05:44 PM
mikeredam's Avatar
0/11 sssss1201
Feedback Score: 50 reviews
waiting for pics....
Old 01-29-2014, 05:46 PM
Active Member
0/11 ssssss967
sorry its the 2 channel...2 pair of them
specs on rca cables
WoofersEtc.com - SHI2320 Stinger - 20 foot - 2 Channel HPM3 RCA Cables
20 foot - 2ch HPM3 Stereo Audio Interconnect
Triple-Shielded
Directional Twisted-Pair Construction (AUDIO)
Rubber Grip Twist-Lock Metal Ends
Machined Shoc-Krome Plated RCA
Split-Tip RCA
Unparalleled Noise Rejection
Unparalleled Accuracy
Outstanding Frequency Response
Outstanding Sound Quality
Satin Chrome Finish
specs on KNF-23 distribution block
http://www.knukonceptz.com/productDe...?prodID=KNF-23
The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KNF-23 has two input ports, which by changing the Kompression Fittings, can accept 4 Gauge or 1/0 Gauge Cable . The two of the three ouputs can be adjusted to accept 4 Gauge or 8 Gauge cables while the last output can be configured for FUSED 1/0 or 4 gauge output . The KNF-23 has 18 Unique Konfiguratons. Please see our reference chart link below to see what fittings are included with this model. Using the Mini-ANL Style Fuse, the KNF-23 can maintain loads up to 150A per circuit.
Included with the KNF-23 are 8 Kompression Fittings to allow the end user to customize the block to fit their application. The fittings available with the KNF-23 are: two large 1/0 Gauge; two large 4 gauge; two small 4 gauge; two small 8 gauge. The large fittings are used on the input side and the middle output while the small fittings are used on the outside outputs of the KNF-23 Also included, your choice of three (3) Mini-ANL fuses! The KNF-23 is finished in black chrome and includes the smoke acrylic cover
KonFUSED System Introduction
To use the KNF-23 as a ground block, select "link" from each fuse drop down. Links are brass buss bars that act as direct links (non fused connections) turning the KNF-23 into a 5 port, multi 0 gauge connection point.
PLEASE NOTE - one KNF-23 can not be used for power AND ground distribution at the same time. Two separate KNF-23s would be required for this type of distribution system.
Old 01-29-2014, 05:58 PM
mikeredam's Avatar
0/11 sssss1201
trades? im interested in the knu distro block
Old 01-29-2014, 09:27 PM
Active Member
0/11 ssssss967
what you have?
Old 01-30-2014, 07:49 AM
Active Member
0/11 ssssss967
pm replied to and nothing sold yet. first to pay gets.
Old 01-30-2014, 01:09 PM
Active Member
0/11 ssssss967
package deal on all of it together...
Old 01-30-2014, 04:34 PM
0/11 ssssss268
Feedback Score: 17 reviews
Payment sent thanks
Old 01-30-2014, 05:12 PM
Active Member
0/11 ssssss967
Block sold.
Stinger HPM3 20ft RCA cable new in box. gentlejax2 Bargain Bin 2 01-29-2014 03:09 PM
FS: KNU 4 chan + Stinger 2 chan rca cables Bushj311 Wiring, Electrical & Other Installation Equipment 2 05-31-2012 03:53 PM
efx (not scoche) 12, 17, and 20ft 2ch rca cables Nudels Wiring, Electrical & Other Installation Equipment 1 05-02-2012 03:47 PM
Stinger HPM3 20ft Interconnects oslouie Bargain Bin 26 08-18-2011 02:26 PM
Wire and fuse holders! KNU 1/0, KNU 4 gauge/ distro block stangman67 Wiring, Electrical & Other Installation Equipment 4 04-15-2011 09:56 PM
