Optima Yellow Top Battery D34/78 - Car Audio Classifieds!
Old 02-16-2014, 02:34 AM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
Feedback Score: 38 reviews
Default Optima Yellow Top Battery D34/78
D34/78 (group 34)
Yellow Top Battery
Performance Data
Cold Cranking Amps: 750
Cranking Amps: 870
Nominal Voltage: 12 volts
Open Circuit Voltage (fully charged): 13.1 volts
Internal Resistance (fully charged): 0.0028 ohms
Capacity: 55 Ah (C/20)
Reserve Capacity: BCI: 120 minutes (25 amp discharge, 80°F (26.7°C), to 10.5 volts cut-off)
Plate Design:
High purity lead-tin alloy. Wound cell configuration utilizing proprietary
SPIRALCELL TECHNOLOGY®.
Electrolyte:
Sulfuric acid, H2SO4
Case: Polypropylene
Case Color: Light Gray
Cover Color: “OPTIMA“ Yellow
Group Size: BCI: 34
Post Type: Dual SAE/GM
Weight: 43.5 lb
Length: 10.06 in
Width: 6.94 in
Height: 7.88 in
BENEFITS OF THE YELLOWTOP®:
Deep-cycle and cranking power
Up to two times longer life
More than 15 times the vibration resistance
Completely spillproof, mountable in virtually any position
Maintenance-free
Faster recharging
Optimal starting power
300+ discharge/recharge cycles
Used in good condition. A little over a year old.
Just pulled from my jeep to replace with an xs power battery. It never let me down, started my vehicle no problem last month when it got down in the negatives outside.
Will come in original box/packaging with battery cover as seen in pics.
$135 SHIPPED OBO
refs:
Old 02-16-2014, 09:49 AM
0/11 ssssss102
Trades?
Old 02-16-2014, 04:16 PM
joe*89's Avatar
UPS FTMFL
0/11 sssss1859
Originally Posted by putthekidstobed View Post
Trades?
I need the cash more.
May trade on 1/0 wire or a small 2ch amp.
Offer up
refs:
Tags
optima yellow top battery
Two OEM Optima yellow top battery covers Wingman0121 Wiring, Electrical & Other Installation Equipment 10 12-20-2012 11:29 PM
Optima yellow top battery bank travisyehle General Car Audio Discussion & Questions 17 09-26-2011 02:38 PM
Optima Yellow Top Diesel Wanting to Buy (WTB) 2 10-11-2010 05:42 PM
FS: Optima Yellow top 34/78 Battery BeAlLsTaR13 Wiring, Electrical & Other Installation Equipment 0 07-14-2010 07:17 PM
