maxwell 3000F cap 16.2 volt bank - Car Audio Classifieds!
Old 03-14-2014, 10:25 PM
BoxxcDD's Avatar
0/11 ssssss730
Default maxwell 3000F cap 16.2 volt bank
1. Product: Maxwell cap bank new never seen power or used just banked with copper bars.
2. Specs: 3000f 2.7 volt per cap 6 bank for 16.2 total power. I payed $402 for the caps alone. $67. per cap.
3. Description/Condition: new
4. Price: :$300 + shipping or best offer
Old 03-15-2014, 10:14 AM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
So I can use this with 16v charging system?
it makes since that if u add an alternator it will add resistants make your MPG go down but i dont see how turning up your volume adds more resistants.
SENSE RESISTANCE
Perhaps a mod could change it to "Massivespfail"?
Old 03-15-2014, 10:28 AM
0/11 ssssss192
Negative. Considering 16 volt batts rest at 16.8 and charge at just under 19 volts, this pack will not have enough cells to be safe at the voltage you're running. You would have to add 1 more cap in series to be safe, preferably 2.
Old 03-15-2014, 10:30 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
So I can use this with 12v charging system?
Sent From Oklahoma
Old 03-15-2014, 10:37 AM
0/11 ssssss192
Sent From Oklahoma
only if the vehicle your installing it into has rubber tires and clear windows.
Also the rear passenger child safety lock has to be halfway engaged or $hit will be bad meow.
Notice I said hallway engaged, if you halfway unengaged it, the turbo encabulator could defuse, and you wouldn't want that!
Lol!
The Following 2 Users Say Thank You to 6thpinned For This Useful Post:
armykyle1 (03-15-2014), e46inperrycounty (03-15-2014)
Old 03-15-2014, 11:57 AM
0/11 sssss4981
Considering my D1400s are charging at 16.2-16.5
SENSE RESISTANCE
Old 03-15-2014, 04:18 PM
BoxxcDD's Avatar
0/11 ssssss730
It is for 12volt systems but you can add caps for 16 volt.
Old 03-15-2014, 04:40 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Thank you sir...
Sent From Oklahoma
Old 03-15-2014, 04:45 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
16.2 is the upper limit of the 6 cell bank. Anything more than that and they could make a mess of your vehicle... and by mess I mean fail and potentially cause a fire.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 03-15-2014, 05:27 PM
BoxxcDD's Avatar
0/11 ssssss730
each cell can do 2.8 volts. Need to sell for cash for woofers.
Twelve (12) Maxwell 2600F 2.5 Volt Ultra capacitors Afterparty Wiring, Electrical & Other Installation Equipment 3 02-03-2014 09:13 PM
mixing batts / cap question (maxwell) stssilverado General Car Audio Discussion & Questions 11 08-19-2013 04:10 PM
cap bank? phatryan69 General Car Audio Discussion & Questions 2 06-25-2013 12:58 PM
Maxwell SuperCaps Bank 6-2.5v (15v 433F) Kevin.Ross Wiring, Electrical & Other Installation Equipment 5 04-26-2013 02:06 PM
(6) Maxwell boost caps-15V bank jstang2003 Wiring, Electrical & Other Installation Equipment 40 12-21-2012 10:46 AM
