JuiceBox Battery - Lithium Iron Phosphate - Pre Ordering - Pricing - Configurations - Car Audio Classifieds!
Old 12-05-2014, 02:19 PM
Active Member
0/11 ssssss846
Feedback Score: 23 reviews
Default JuiceBox Battery - Lithium Iron Phosphate - Pre Ordering - Pricing - Configurations
JuiceBox Lithium Iron Phosphate Battery
Available in 6v/12v/16v/18v.
Min Order 500WH (0.5KWH)
Custom Designed to Meet Customers Requirements Please see FAQ for a breakdown of what is available.
Lithium Iron Phosphate FAQ
For reference all videos below is of our 0.5kwh (12v 40AH configuration)
Specifications:
Nominal Voltage: 13.3v
Max Voltage: 14.8v
Min Voltage: 8.0v
Chemistry: Lithium Iron Phosphate (LiFePO 4)
Capacitance: 40Ah
Reserve Capacitance: 100 Minutes
Internal Resistance: 1.2miliΩ
Burst Discharge (5 Seconds): 2,600 Amps / ~31,000 watts
Continuous Discharge: 1,000 Amps / ~ 12,000 watts
Continuous Charge: 400 Amps
Burst Charge (5 Seconds): 1000 Amps
Operating Temperature: -20F to 120F
Over-Charge Protection
Over-Discharge Protection
Detailed Breakdown of Load Test Results.
Testing was done on AutoMeter SB-5DT. This meter uses 2 gauge OFC wire and copper alligator clips. This meter is rated not to exceed 500 Amps. All testing was done on the same day with small 2-3 minute pauses before runs to allow for ample cooling time. Tests were done from Largest, 500 Amps, to lowest, 200 Amps, and no charge was given between tests.
Load Tests (500AMP, 400AMP, 300AMP, 200AMP): All tests were preformed in order, no charging was done in between testing.
500 AMP BreakDown
Starting Voltage: 13.83v
@500 Amp Start Voltage: 12.21v
Duration: 10 Seconds (Machine Thermal Limit Reached)
@500 Amp End Voltage: 11.83v
@500 Amp Average Voltage: 12.02v
Stand Alone Power ( No Additional Power Source)
12.02v x 500 Amps = 6,010 Watts
Stand Alone Power x Common Amplifier Efficiency's
@90% = 5,409 Watts
@70% = 4,207 Watts
@50% = 3,005 Watts
Juicebox Lithium Iron Phosphate 40ah Battery - 500 amp load test - YouTube
400AMP Breakdown
Starting Voltage: 13.34v
@400 Amp Start Voltage: 12.31v
Duration: 17 Seconds
@400 Amp End Voltage: 12.03v
@400 Amp Average Voltage: 12.17v
12.17v x 400 Amps = 4,868 Watts
@90% = 4,381 Watts
@70% = 3,408 Watts
@50% = 2,434 Watts
Juicebox 40ah Lithium Iron Phosphate - 400 amp load test - YouTube
300AMP Breakdown
Starting Voltage: 13.30v
@300 Amp Start Voltage: 12.52v
@300 Amp End Voltage: 12.23v
@300 Amp Average Voltage: 12.38v
12.38v x 300 Amps = 3,714 Watts
@90% = 3,343 Watts
@70% = 2,600 Watts
@50% = 1,857 Watts
Juicebox 40AH Lithium Iron Phosphate Battery - 300 amp load test. - YouTube
200AMP Breakdown
Starting Voltage: 13.26v
@200 Amp Start Voltage: 12.72v
Duration: 22 Seconds
@200 Amp End Voltage: 12.48v
@200 Amp Average Voltage: 12.60v
12.60v x 200 Amps = 2,5020 Watts
@90% = 2,268 Watts
@70% = 1,764 Watts
@50% = 1,260 Watts
Juicebox Battery Lithium Iron Phosphate 40 AH - 200 amp load test - YouTube
All orders are built to customer specifications and lead time is 1-2 weeks for completion.
THIS IS PREORDER PRICING, NO REFUNDS, Expected Delivery Mid to late January.
Pre Orders must be in Prior to Jan 15, 2015
$1200 per 500wh (0.5kwh) Example - 12v/40AH
FIRST 20 UNITS WILL BE OFFERED AT $995 SHIPPED
After Jan 15, 2015 Retail Pricing $1,500 per 0.5KWH
Covered with our 3 Year Transferable Free Replacement Warranty. The first 5 Customers will receive an additional 2 year extended warranty free of charge ($200 value), for a total of 5 years of protection.
PAYMENT CAN BE SENT VIA PAYPAL TO [email protected] or processed over the phone.
Juicebox Battery Online Operations Manager.
The Following 2 Users Say Thank You to Kevin.Ross For This Useful Post:
Haelmuscle (12-05-2014), iamsonic (12-05-2014)
Old 12-05-2014, 03:35 PM
0/11 ssssss518
Oh my
Old 12-05-2014, 07:18 PM
0/11 sssss1882
I first looked and said "damn a $1k battery!' But then realized this thing is strong enough to replace entire banks. I then rethought " damn! Only a $1k battery!"
The Following 3 Users Say Thank You to southernbass For This Useful Post:
80INCHES (12-14-2014), sandmanll06 (06-13-2015), TaylorFade (12-05-2014)
Old 12-05-2014, 07:32 PM
Active Member
0/11 ssssss846
Power Density is comparable to 5 Group 31 AGM's. At only ~30lbs, theirs more than just an initial cost to consider. MPG's, physical space, etc. I truly appreciate all the love and support from competitors to every day ground pounders. We are only getting started
80INCHES (12-14-2014), 98GMC (01-23-2015)
Old 12-05-2014, 07:51 PM
0/11 ssss31257
ok..
how many black cherry's{$225} = 1 Lithium {$1000}
Old 12-05-2014, 07:58 PM
TEAM TANTRIC
0/11 ssssss553
Black cherrys are group 31's so 5
Team Deadly Hertz
Team Tantric
Team Ampere
AMPERE AUDIO/TANTRIC/SCHA/SINGER/XS
Old 12-05-2014, 08:12 PM
Active Member
0/11 ssssss846
Correct, it is comparable to 5 of our Black Cherry batteries.
Old 12-05-2014, 08:38 PM
0/11 ssssss437
Can these be charged with an alternator and do they have a built in voltage cut off so you don't damage the battery when dropping to low?
Old 12-05-2014, 08:48 PM
Active Member
0/11 ssssss846
Yes they can be charged with an alternator. Yes it will not be damaged by low voltage.
Old 12-05-2014, 08:54 PM
0/11 sssss1882
I would think most amps would hit protect/fry by time you got into the 8-9v region of the batteries protect circuit.
You put a lot of good info out here Kevin.
Now I don't mean to be prying into the privacy of the business world, but how long have you guys tested these? Just curious as to an average life span of these in prime (I mean keeping voltage 11.5-12+) high discharge environments. I see you are warrantied into the 5 year mark. Puts a lot of confidence in the product.
JuiceBox Battery Lithium Iron Phosphate, Frequently Asked Questions and Answers Kevin.Ross CACO Service Providers 14 12-15-2014 08:10 PM
JuiceBox new Lithium battery (video) TaylorFade General Car Audio Discussion & Questions 10 12-04-2014 03:42 PM
JuiceBox Battery - Latest Lithium Iron Phosphate Prototype Load Test Analysis Kevin.Ross Testing & Scientific Data Discussion 5 11-08-2014 07:07 PM
Pre pre-ordering (not a typo) pricing for subwoofers. Electrodynamic General Car Audio Discussion & Questions 101 12-06-2010 11:30 PM
