Ohmega switch - Car Audio Classifieds!
Old 01-10-2016, 03:06 PM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Default Ohmega switch
Ohmega switch
Switches speaker voicecoil configurations. EX. 1ohm to .25 ohm with a twist of a switch
Brand new, just took it out for pictures
$67shipped US ONLY
my package is on here somehwere... someone find it lol
yeeeahhh.
Im banning you now...
Old 01-10-2016, 06:46 PM
0/11 ssssss452
Pretty kool. Whats the standard ratio, like 4ohm goes to 1ohm, 3ohm goes to? Edit: I reread it and see your example more clearly now. So dropping to a quarter of "daily" to "burp" is a standard and constant?
Missin Texas
Old 01-10-2016, 08:37 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
Essentially yes. Since you are switching from series to parallel you will always have 2 groups of coils that each set is either halved the power or doubled the power times 2 groups so it's always a factor of 4.
Even say like 16 dual 4 ohm subs could be wired to switch from .5 to 2 ohms.
Current Build:
#60sHereIcome
The Following 2 Users Say Thank You to SINTORMAN For This Useful Post:
carshateme (01-11-2016), wanderer1 (01-10-2016)
Old 01-11-2016, 10:20 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
It's prefect for competition lanes and demos. Only downfall is that it's on the big size for a switch...but I can see the beefiness in the hardware. Just turned another way with car audio
yeeeahhh.
Old 01-14-2016, 08:55 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Up to the top!
yeeeahhh.
Old 01-19-2016, 09:25 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Going back up!!!
yeeeahhh.
Old 01-25-2016, 12:14 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Back up to the top
yeeeahhh.
Old 02-02-2016, 10:30 PM
0/11 ssssss117
If switching the impedance with a switch dont you need to reset the amp gain going from 1ohm to .25?
Old 02-03-2016, 01:28 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
No.......
My game is legit,
Old 02-03-2016, 03:35 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
No. If you're gain is set correctly. All you do is change your wiring from series to parallel. But with the switch...all you do is turn a knob. Saves a tremendous amount of time while competitng and giving demos.
Example: I am at a show. I have my subs wired to 1 ohm. I'll give demos at 1 ohm. Now when I drive up to the meters. I'll switch it to .25 ohms to do burps to get that better deebeez.
yeeeahhh.
Ohmega Switches Ordering Thread SINTORMAN Wiring, Electrical & Other Installation Equipment 40 03-16-2016 07:44 AM
Ohmega Switch SPL Testing SINTORMAN Testing & Scientific Data Discussion 0 12-17-2015 01:29 AM
Trying out a Vendor position. Ohmega Products SINTORMAN New Member Orientation 12 09-10-2015 07:23 PM
Ohmega switch 2nd order 18psi General Car Audio Discussion & Questions 1 07-28-2015 06:49 PM
Should I switch? crownvicon26's General Car Audio Discussion & Questions 5 01-05-2011 08:49 PM
