CALB 100 ah Lipo4 cells - Car Audio Classifieds!
Old 11-12-2016, 07:20 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Default CALB 100 ah Lipo4 cells
Capacity: 100Ah
Height: 215 mm (8.46 inch)
Width: 67 mm (2.64 inch)
Length: 142 mm (5.60 inch)
Weight: 3.2kg (7.0 lbs)
Bolt Size: M8
Voltage nominal: 3.2V
Charge voltage cut-off: 3.6V
Discharging cut-off: 2.5V
Life Cycle (0.3c Charging-Discharging, 80%DOD): 2000
Maximum Discharging Current (10 sec.): 800 Amps
Internal Impendance (1khz Ac, m-Ω): Less Than 0.8
Chemistry: LiFePO4
Voltage: Nominal 3.2. Fully charged - 3.35v.
Charge Voltage: 3.65v - use 3.55v for series strings.
Discharge Cutoff: 2.50v
Standard Charge/Discharge: 0.3 C (33 amps).
Max Charge: 3C (300 amps)
Max Continuous Discharge: 3C - 300 amps.
10 second Discharge: 8C - 800 amps.
Height: 8.5 inch/216mm
Width 5.5 inch/142 mm
Thickness: 2.64 inch/67mm
Weight: 7.05 lbs/3.2kg
they are used. were origoanlly used for solar test setup but then i bought them. Tested them with load tester and 14.4 dc source.
$300 shipped per bank have 2 banks total (4 cells each)
$500 for both banks shipped
Old 11-19-2016, 01:16 PM
djscrubb's Avatar
0/11 sssss2332
Price lowered bump
Old 01-08-2017, 05:44 PM
0/11 sssss1068
Still available?
Old 02-09-2017, 08:56 PM
0/11 sssss1068
Hello? If they aren't available take post down
Old 02-10-2017, 08:31 AM
djscrubb's Avatar
0/11 sssss2332
Sorry sold locally
Reikken power cells bass305 General Car Audio Discussion & Questions 11 07-03-2013 03:15 PM
Lets talk 2V and 4V cells murderedtahoe General Car Audio Discussion & Questions 11 09-15-2012 03:58 PM
Hawker Cyclon cells- 4.5AH DT size (44 in total) winslow Wiring, Electrical & Other Installation Equipment 12 05-17-2012 08:51 PM
WTB Sundown SAX 125.2, 100.2, 100.4 ClickClickBoom Wanting to Buy (WTB) 15 06-08-2010 05:24 PM
