BNIB Trunk/Door Pop Solenoid Kit (x2) - Car Audio Classifieds!
Old 01-15-2010, 09:40 AM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
Feedback Score: 21 reviews
Default BNIB Trunk/Door Pop Solenoid Kit
1. Product: Door/trunk pop solenoid kit One sold...One left.
2. Specs: 15 Pounds of pull pressure
3. Description/Condition: Easily add a power trunk release to almost any vehicle; can also be used to "pop" doors with shaved handles. This kit can be used with or without an alarm, remote start or keyless entry system. It comes complete with mounting hardware, interior switch, wiring harness with fuse and instructions.
4. Price: $15; USPS shipping w/Delivery Confirmation (to CONUS) and PayPal fees included. Buy with confidence: click the site name to check out my 100% positive feedback on CarAudioClassifieds, RCGroups, eBay, RunRyder, and RCUniverse. Thanks for looking...rock on!
Push the Envelope...Watch it Bend
Old 01-15-2010, 10:00 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
how does this work?
Does it just pop it open a bit and you gotta manually open the trunk? or it opens the whole trunk open?
- CALI SOUNDS
- VERTEX AUDIO
Old 01-15-2010, 10:09 PM
0/11 sssss1560
I think it basically opens a small amount and if your trunk would open with that small amount then yes, if not you would need an actuator not a popper
Old 01-15-2010, 10:29 PM
xseveredveganx's Avatar
Chainsaw Squad
0/11 sssss3380
Originally Posted by gboo559 View Post
how does this work?
If you shave your door handles, or trunk lid, you need some way to open the bear-claw type latch on the inside of the door. You set this up (usually at the bottom of your door) rigged with a cable between the popper and the latch itself. I recommend welding the lock mechanism open, so the latch doesn't somehow get locked.
I've daily driven shaved cars for years.
Old 01-15-2010, 11:29 PM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
how does this work?
For trunk applications:
The solenoid is mounted in the trunk lid and performs the same action as a key being turned in the lock, so yes, you still have to manually open the lid.
For shaved door handle applications:
The solenoid is mounted inside the door and performs the same action as lifting/pulling the door latch handle. There are "door poppers" available also, which are basically spring-loaded rods that you install in each door jamb so when you hit the door open button the door "pops" open a foot or so.
Hope this helps
Old 01-17-2010, 04:34 PM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
To the Top
Old 01-17-2010, 05:14 PM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
To the Top
Old 01-17-2010, 05:19 PM
0/11 sssss3842
tempting.......
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 01-18-2010, 12:28 AM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
Originally Posted by tylork92 View Post
tempting.......
They could be on their way to you Monday morning...you'd have 'em in hand by Thursday
Old 01-21-2010, 08:46 PM
toolguy420's Avatar
Loyal Member
0/11 sssss1194
To the top
Will these XXX mids fit in ANY door? hornedfrog1985 General Car Audio Discussion & Questions 7 08-19-2009 08:09 PM
my first set of glassed door panels JOSEPHKEMP Build Logs 26 06-09-2009 01:28 PM
would some one please help me with these door pods? waresgaragestereo General Car Audio Discussion & Questions 30 11-01-2008 06:21 AM
Look what showed up at my door Patrick Simmons General Car Audio Discussion & Questions 7 09-08-2008 09:54 AM
