[SOLD]Autostart AS-2775 remote start system - Car Audio Classifieds!
Old 02-20-2010, 04:06 PM
0/11 sssss7816
Default [SOLD]Autostart AS-2775 remote start system
1. Product: Autostart AS-2775
Unit Specific Features
Two 5-button transmitters
Up to 2200 ft / 670 m range
Monopole antenna with embedded bright-blue LED
Safe start
Swap start
Home valet mode
Remote controlled valet mode
Ignition monitoring
Multi-car operation
5th button with stop / panic functions
Unit Specific Options
Built-in programmable OEM-style alarm
Virtual Tach System (automatic transmission mode only)
Aux. 1: Horn or priority door access
Aux. 2: Priority door access, constant while pressed or latched 30 sec./4 min.
Aux. 3: Configurable trunk output
Configurable input: - Trunk pin monitoring - External trigger - Key sense
Starter Base Features
Multi-speed tachometer learning
Normal and high tach jumper
Programming assistance button
Negative hood trigger input
Tachometer input
Auxiliary (-) ground output when running
Positive glow plug input
Gas or diesel engine compatible
Non-volatile system state memory
iDatalink compatible
Pager compatible
RS-232 port
INV-200 port
Configurable engine run time
3 minutes in gas mode / 8 minutes diesel mode
15 minutes in gas mode / 20 minutes diesel mode
25 minutes in gas mode / 30 minutes diesel mode
Turbo mode
Idle mode
Cold weather mode
Limited lifetime warranty
Dual 12-volt power wires
High-current outputs for Ignition, Accessory and Start
Configurable high-current output for 2nd ignition, 2nd accessory and 2nd start
Ignition controlled valet mode
Starter Base Options
Keyless entry outputs
Ignition controlled door lock
Trunk release output
Anti-theft starter-kill output
Passive or active starter-kill arming
Arm & disarm OEM alarm
Secure lock
Parking lights flash / diagnosis
OEM horn control
I opened it and crimped spade style connectors to go with the wire taps for the system, but never installed, the taps are included.
4. Price: $50 shipped
Old 03-13-2010, 12:41 AM
0/11 sssss7816
bump
Old 03-13-2010, 01:06 AM
Real Talk
0/11 ssssss291
nice, iDatalink compatible is the way to go
Their bypasses are much better than Directed's IMO
GLWS
NICE weiner
I have a mini-weiner
. I'll post pics in a min.
Old 03-13-2010, 01:26 AM
0/11 sssss7816
Sold
Atomic Loudspeakers
Audiotechnix
Autostart AS-2775 worstenemy453 Miscellaneous Stuff For Sale 19 06-19-2009 12:15 AM
Autostart Remote Starting System worstenemy453 Miscellaneous Stuff For Sale 1 02-22-2009 03:15 PM
Need help with remote start. sdelthon General Automotive Chat 14 02-06-2009 10:18 AM
remote start, how hard is it? aturcotte127317 General Automotive Chat 18 01-15-2009 04:29 PM
