Wired/Orion MBR70 Battery Isolator - Car Audio Classifieds!
Old 08-15-2010, 01:04 PM
chapdawg1971's Avatar
Semi-Loud Trunk
0/11 sssss1950
Feedback Score: 25 reviews
Default Wired/Orion MBR70 Battery Isolator
1. Product: Wired/Orion MBR70
2. Specs: The MBR 70 is a "smart" regulator/isolator that senses the needs of the vehicles battery and any additional batteries. Unlike conventional battery isolators, the MBR 70 requires no cutting into the factory electrical system. It allows all the batteries in your vehicle to become a collective voltage source.
The MBR 70 ensures the proper voltage level in the vehicles battery by concentrating solely on that battery until it sees a charge voltage above 12.5 volts. Once this voltage level has been established, the MBR 70 couples all the batteries so they can be charged.
When your engine is running, the MBR 70 allows the alternator to feed the auxilliary batteries a regulated charge up to 70 amps.
When the ignition is turned off it becomes a one way gate, isolating the current in the vehicles battery from passing through to the auxilliary batteries . This one way gate ensures that the vehicle's battery will always have enough charge to start the car, regardless of the charge status of the aux batteries.
3. Description/Condition: Excellent shape/ see pics.....the "In"-Vehicle's battery input hole was drilled out to accept 1/0, but had to use a 1/0 to 4 gauge adapter to use it. I have a paper manual as well.
4. Price: : $100 shipped
5. Pictures: VVVVVV
Old 08-16-2010, 06:12 AM
Semi-Loud Trunk
0/11 sssss1950
Up. Will trade toward a nice H/U with cash on my end.
Old 08-18-2010, 02:07 AM
0/11 sssssss17
I want it!
please email me at [email protected]
Old 08-18-2010, 01:15 PM
Semi-Loud Trunk
0/11 sssss1950
I sent you an email.
Old 08-18-2010, 01:23 PM
pickup1's Avatar
old guy
0/11 sssss1348
dont you get a .7 volt drop with an isolater like this?
Old 08-18-2010, 01:48 PM
Semi-Loud Trunk
0/11 sssss1950
This is my third iteration of this type of regulator and I've personally never noticed anything like that.
Old 08-18-2010, 01:54 PM
0/11 sssssss17
Default 1/0 power/ground wire
How do you use 1/0 power/ground wire with this device?
Nudels's Avatar
SNOTFACE!
0/11 sssss5371
same thing as the original orion mbr 70, correct?
who wants a nudel ride?
Old 08-18-2010, 01:58 PM
Semi-Loud Trunk
0/11 sssss1950
.....well, except during musical transients and then the volt meter dips into the mid to low twelves sometimes.
Old 08-18-2010, 03:30 PM
Semi-Loud Trunk
0/11 sssss1950
Yep, identical to the Orion one.
The output has been opened up so you can run 1/0 to your additional batteries. There is no ground in or out, as can be seen in the pics. What this more or less does is make your battery(s) in the trunk or where ever you may have them mounted totally seperate from the main battery. What I did was use my front battery to power my front stage and the ones that were separate powered my sub stage. Nice piece and worked well.
Orion Wired MBR 70 Multiple Battery Regulator scottishb Wiring, Electrical & Other Installation Equipment 12 09-20-2010 09:33 AM
battery isolator fyerbyrd22 General Car Audio Discussion & Questions 27 02-04-2010 06:31 PM
Stinger Battery Isolator crownvicon26's Wiring, Electrical & Other Installation Equipment 1 10-27-2009 04:49 PM
battery isolator nuboot General Car Audio Discussion & Questions 1 06-01-2009 07:13 PM
WTB: Orion MBR70. IBProAudio Wanting to Buy (WTB) 0 05-25-2009 11:03 PM
