Originally Posted by dj00140
hmmm whats the deal with welding wire and 600 amps? isnt that like 8k watts? is welding better then regular speaker OFC?
Welding cable is rated @ specs that are relevant to welding. So it's rated at "x" amperage at very high voltages, like with what welding uses.
I do believe it's rated at higher amperages since it's lower voltage use, but I'm not 100% on that.
Comparatively, this cable will easily compete with most car audio 3/0 and 4/0 size cables, although that size cable in car audio wire is basically non-existent.
