[SOLD]Speaker Box Terminal Sets - Car Audio Classifieds!
Old 12-21-2010, 11:46 PM
TNJ
0/11 sssss7882
Default [SOLD]Speaker Box Terminal Sets
Complete kit for box post terminals with wire
each kit includes:
2-1 3/4" long (1 1/2" main shaft)
8- 3/4" diameter washers
4- 1/2" diameter nuts
1 run of 12 gauge EFX speaker wire with red and black terminals on ends marking positive and negative with eyelet that fit terminals
These fit a single sheet of 3/4" mdf, not ment for doubled up sheets as they are not long enough.
they are used but wire is in great condition and bolts are practically brand new as well.
worked great, had them set up like this:
bolt-washer-eyelet with wire to inside box that leads to speaker-washer-3/4"mdf-nut-washer-eyelet with wire to amp-washer-nut.
if that makes any sense to you guys. haha.
6 dollars shipped for 1 kit (2 bolt sets, and 1 run of 12 gauge speaker wire w/ terminals). 10 shipped for 2 kits (for running 2 amps or multiple subs)
one terminal includes this (so this would be positive lets say, another would be negative):
wire ends:
Old 12-21-2010, 11:51 PM
Prohibited Sellers/Buyers
0/11 sssss1326
how much for whole lot?
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Nice deal there GL...
Old 12-21-2010, 11:52 PM
Pieper's Avatar
Winston Churchill > You
0/11 sssss9716
Feedback Score: 84 reviews
Stainless steel bolts?
TNJ
0/11 sssss7882
pm coming your way
thanks. got rid of box so no need for them anymore. might as well help out a member and hook them up with a whole little kit. haha.
Old 12-21-2010, 11:53 PM
TNJ
0/11 sssss7882
Old 12-22-2010, 12:04 AM
0/11 ssssss911
you sir come up with good ideas on ur "packages".
Old 12-22-2010, 12:07 AM
TNJ
0/11 sssss7882
it worked rather well. its nice having the second bolt there so you can remove the terminals without worrying about the bolts falling into the box.
Old 12-22-2010, 12:09 AM
Pieper's Avatar
0/11 sssss9716
Offically stealing this idea for the silicon bronze ones I'm using right.
speaker terminal? poundstone General Car Audio Discussion & Questions 11 09-06-2010 09:35 PM
3kw Amp speaker Terminal stripped out 87linkin (Crescendo) 5 07-20-2010 03:35 PM
3kw Amp speaker Terminal stripped out 87linkin (Crescendo) 0 07-18-2010 06:36 PM
speaker terminal power handling? Allstar71 Enclosure Discussion & Design Construction Help 2 10-26-2009 11:02 PM
[SOLD]Terminal Plates RidnClean Wiring, Electrical & Other Installation Equipment 13 12-09-2008 11:19 PM
